Home » Modeling » Graphiti » generate stand alone java application(how to generate the plugin run it as a stand-alone java application or integrate it with other applications)
icon4.gif  generate stand alone java application [message #1698354] Sun, 14 June 2015 16:49 Go to next message
Hello everybody
I have my graphiti editor ready and I'm wondering how can I generate the plug in as stand alone java application or integrate it with other java applications ?
thanks
Ayoub,
Re: generate stand alone java application [message #1698867 is a reply to message #1698354] Thu, 18 June 2015 09:09 Go to previous message
Ayoub,
for a standalone application you will probably need to create an Eclipse RCP
application (based on Eclipse 3.x). There are tutorials out in the web how
to do that, e.g. http://www.vogella.com/tutorials/Eclipse3RCP/article.html
Not sure what exactly you mean with integration into other Java
applications. In case you mean to install your plugin/editor into any other
Eclipse installation, the usual way to do that is to provide an update site
containing yout editor and allow users to install it from there.
HTH,
Michael
Previous Topic:Editor shapes are red after changing model in another editor
Next Topic:Select DiagramEditpart after opening the Diagram to show the propertysheet for the same.
Current Time: Mon Jul 21 23:45:50 EDT 2025
Powered by FUDForum. Page generated in 0.03745 seconds
