Home » Eclipse Projects » Nebula » CDateTime -> do not show the "clear" button in toolbar
CDateTime -> do not show the "clear" button in toolbar [message #1697498] Thu, 04 June 2015 08:05 Go to next message
Is there a way to remove or hide the "Clear" button in the top toolbar (next to the tick mark and cancel) at the top of the drop down?
I checked the CDateTimeBuilder. It looks like I can control header, body, and footer, but not the toolbar.
Background: I want users to select a date. If I allow null values, I have to add validation logic at other places which I like to avoid. And it confuses uses that one can clear the date only to get an error message.
Re: CDateTime -> do not show the "clear" button in toolbar [message #1697555 is a reply to message #1697498] Thu, 04 June 2015 16:08 Go to previous messageGo to next message
Hi Andreas,
If you supply a patch through Gerrit that scratches your itch then I am happy to review it. Please file a bug and read the Nebula contribution guide.
Wim
Re: CDateTime -> do not show the "clear" button in toolbar [message #1697612 is a reply to message #1697555] Fri, 05 June 2015 07:44 Go to previous messageGo to next message
Thanks Wim for the quick response and answer! Not sure if I get around to supply a patch.
Thanks also for the great work around Nebula.
Re: CDateTime -> do not show the "clear" button in toolbar [message #1701043 is a reply to message #1697612] Wed, 08 July 2015 16:57 Go to previous message
Hi Andreas,
At least file a bug Wink
Wim
http://wiki.eclipse.org/Nebula/New_Contributions
Previous Topic:FormattedText not allowing 0 to be entered
Next Topic:Tab key navigation in the grid.
Current Time: Wed Jul 16 06:49:00 EDT 2025
Powered by FUDForum. Page generated in 0.03774 seconds
