Home » Eclipse Projects » Sirius » NullPointerException when reopen Sirius Diagram
NullPointerException when reopen Sirius Diagram [message #1697184] Tue, 02 June 2015 04:32 Go to next message
Hi Smile ,
First i've to introduce my project and the way to get the error to help you to understand it.
I've got a Sirius project based on an EMF witch is compose of two .ecore files.
So i made my viewpointSpecificationProject, the modeling project containing the representation.aird and the xml and everything works.
Until i cut my eclipse and reopen it. When i do it a message say to me "Failed to create the part's controls" and in the error log i've got three errors, i put the log below.
I tried some solutions such as cleanning the project environnement, restarting eclipse, deleting the .metadata, downloading the 2.0.5 version of sirius.
If i do the right click and validate, no error occurs and my sirius works fine with an other emf.
So if you've got an idea of the origin of the problem or a solution that could work, i'm interested!
Best regards
Sébastien Dossot
Error log:
eclipse.buildId=4.4.2.M20150204-1700
java.version=1.8.0_31
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data D:\Users\T0162584\Documents\Mes Outils Personnels\IDEs\eclipse\eclipse\work/../runtime-configSirius -dev file:D:/Users/T0162584/Documents/Mes Outils Personnels/IDEs/eclipse/eclipse/work/.metadata/.plugins/org.eclipse.pde.core/configSirius/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
org.eclipse.e4.ui.workbench
Error
Tue Jun 02 09:52:45 CEST 2015
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.persistViewerSettings(DiagramEditor.java:1331)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.dispose(DiagramEditor.java:675)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.dispose(DiagramDocumentEditor.java:213)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.dispose(DDiagramEditorImpl.java:731)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:147)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:99)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:327)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:888)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:869)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:120)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:337)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:258)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:127)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:983)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:662)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1246)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:103)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:678)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:69)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:674)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:547)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:531)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:69)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:185)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:663)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1078)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Error
Mon Jun 01 15:53:57 CEST 2015
at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramSynchronizer.getAllMandatoriesAdditionalLayers(DDiagramSynchronizer.java:328)
at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramSynchronizer.activateNewMandatoryAdditionalLayers(DDiagramSynchronizer.java:296)
at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramSynchronizer.refreshOperation(DDiagramSynchronizer.java:357)
at org.eclipse.sirius.diagram.business.internal.experimental.sync.DDiagramSynchronizer.refresh(DDiagramSynchronizer.java:340)
at org.eclipse.sirius.diagram.business.internal.sync.DDiagramSynchronizer.refresh(DDiagramSynchronizer.java:91)
at org.eclipse.sirius.diagram.business.internal.dialect.DiagramDialectServices.refresh(DiagramDialectServices.java:238)
at org.eclipse.sirius.business.internal.dialect.DialectManagerImpl.refresh(DialectManagerImpl.java:117)
at org.eclipse.sirius.business.internal.dialect.DialectManagerImpl.refresh(DialectManagerImpl.java:105)
at org.eclipse.sirius.diagram.ui.business.internal.command.RefreshDiagramOnOpeningCommand.doExecute(RefreshDiagramOnOpeningCommand.java:61)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.emf.common.command.CompoundCommand.execute(CompoundCommand.java:261)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:208)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.launchRefresh(DDiagramEditorImpl.java:1236)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.initializeGraphicalViewer(DDiagramEditorImpl.java:1441)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.createOriginalGraphicalViewer(DDiagramEditorImpl.java:1408)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.createMainDiagramSection(DDiagramEditorImpl.java:1328)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.createGraphicalViewer(DDiagramEditorImpl.java:1317)
at org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(GraphicalEditor.java:171)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.createPartControl(DiagramEditor.java:1580)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFlyOutPalette.createPartControl(DiagramEditorWithFlyOutPalette.java:328)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.createPartControl(DiagramDocumentEditor.java:1514)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.createPartControl(DDiagramEditorImpl.java:426)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:141)
org.eclipse.ui
Error
Mon Jun 01 15:53:59 CEST 2015
Unhandled event loop exception
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Widget is disposed)
at org.eclipse.swt.SWT.error(SWT.java:4441)
at org.eclipse.swt.SWT.error(SWT.java:4356)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:139)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4147)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3764)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4327)
at org.eclipse.swt.widgets.Widget.error(Widget.java:476)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:348)
at org.eclipse.swt.widgets.Scrollable.getVerticalBar(Scrollable.java:238)
at org.eclipse.draw2d.FigureCanvas$2.propertyChange(FigureCanvas.java:102)
at java.beans.PropertyChangeSupport.fire(PropertyChangeSupport.java:335)
at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:327)
at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:263)
at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:283)
at org.eclipse.draw2d.DefaultRangeModel.firePropertyChange(DefaultRangeModel.java:63)
at org.eclipse.draw2d.DefaultRangeModel.setAll(DefaultRangeModel.java:122)
at org.eclipse.draw2d.FreeformViewport.readjustScrollBars(FreeformViewport.java:74)
at org.eclipse.draw2d.Viewport.validate(Viewport.java:381)
at org.eclipse.draw2d.Figure.validate(Figure.java:1898)
at org.eclipse.draw2d.DeferredUpdateManager.performValidation(DeferredUpdateManager.java:218)
at org.eclipse.draw2d.DeferredUpdateManager.performUpdate(DeferredUpdateManager.java:190)
at org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(DeferredUpdateManager.java:44)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:136)
... 24 more
Re: NullPointerException when reopen Sirius Diagram [message #1697637 is a reply to message #1697184] Fri, 05 June 2015 10:05 Go to previous messageGo to next message
Hi Sébastien,
I think the main error is the NPE in the synchronizer:
>> java.lang.NullPointerException
>> at
>> at
>> at
>> at
>> at
>> at
>> at
The other stacks are side effects of the first one.
Could you give us more information about your environment ?
. Version of Eclipse ? Juno, Kepler, Luna ? SR1, SR2 ?
. Is your metamodel deployed ? Are the two ecore files your metamodel ?
. Do you launch a runtime to use your current VSP ? Or do you directly
use it in yout current IDE ? (To know if the issue occurs with your VSP
deployed or not).
. Was the diagram saved before restart ?
For the moment and with your stacks I see where the NPE might occurs,
but I am not able to reproduce it on my computer.
Maxime - Obeo
Need professional services for Sirius?
Le 02/06/2015 10:32, Sebastien Dossot a écrit :
> Hi :) ,
> files. So i made my viewpointSpecificationProject, the modeling project
> version of sirius.
> Best regards
> Sébastien Dossot
> Error log:
> Quote:
>> java.vendor=Oracle Corporation
>> Error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
>> at
>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
>> at
>> at
>> at
>> at
>> at
>> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
>> at
>> at
>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
>> at
>> at
>> at
>> at
> Quote:
>> Error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> Quote:
>> org.eclipse.ui
>> Error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 24 more
Re: NullPointerException when reopen Sirius Diagram [message #1697644 is a reply to message #1697637] Fri, 05 June 2015 10:54 Go to previous messageGo to next message
Hi Maxime,
.My eclipse version : Luna SR2 (4.4.2)
.I'm not sure of what you mean about deploy my metamodel but if it's generate model, edit and editor code, yes it is. Maybe it could help you :
index.php/fa/22097/0/index.php/fa/22098/0/
.Actually i have my eclipse with my three projects containing model, edit and editor code and then i run as eclipse Application. And my VSP is in this new window.
(i hope this was the question)
.Yes i saved it.
PS: i don't know if it change anything but i created my model by importing some existing xsds
If you have other questions, i can answer it,
Thank you for your response,
Best regads,
Sébastien
[Updated on: Fri, 05 June 2015 11:08] by Moderator
Re: NullPointerException when reopen Sirius Diagram [message #1697649 is a reply to message #1697644] Fri, 05 June 2015 11:18 Go to previous messageGo to next message
Le 05/06/2015 16:54, Sebastien Dossot a écrit :
> Hi Maxime,
If your aird is in a runtime and your metamodel is in the launching IDE,
your metamodel is deployed.
From the stack, it seems that Sirius does not success in it seems that
Sirius does not retrieve the session of the diagram you try to open.
How do you open the diagram when you get this stack ?
. Double click or contextual menu in the Model Explorer ?
. It is just a restart from runtime and so the editor is restored from
memento ?
.Do you know on which element this diagram was created ? Does this
element still exist in your model ? Was it a transient element ?
The fact that Sirius does not retrieve the Session seems to come from an
EObject without resource.
> Yes i saved it.
> Best regads,
> Sébastien
Maxime - Obeo
icon10.gif  Re: NullPointerException when reopen Sirius Diagram [message #1697757 is a reply to message #1697649] Mon, 08 June 2015 04:31 Go to previous message
Hi maxime,
Thanks to you, i found the error.
On my root element (automatically generated when i imported my xsd) i had an EAnnotation (automatically generated too) , in this EAnnotationthe there was a "Detail entry" element with a key "name" and an empty value. So i just deleted this "Detail entry" and now the NPE does not occurs anymore.
I don't know why the emf's validation didn't raise an error and juste raise a NPE when restarting eclipse.
Best regards Very Happy ,
Sébastien
[Updated on: Mon, 08 June 2015 04:39] by Moderator
Previous Topic:Sirius / EMF : How to edit model elements programmatically ?
Next Topic:Duplicate message - can be deleted
Current Time: Mon Nov 03 13:35:03 EST 2025
Powered by FUDForum. Page generated in 0.04435 seconds
