Home » Eclipse Projects » Eclipse Platform » How to Import a parent folder and its contents into a Project, not just the contents?
How to Import a parent folder and its contents into a Project, not just the contents? [message #1697001] Sat, 30 May 2015 12:51
In Eclipse's ProjectExplorer window, I create a new generic Project == "SAMPLES".
I want to import several folders from several sources/locations into the Project.
As a first example, in the "SAMPLES" project, I click "Import ...", and navigate to a Local folder "/usr/local/SAMPLE1". This folder contains
	/usr/local/SAMPLE1
		ITEM1-1
		ITEM1-2
If I select that folder, only its CONTENTS are imported. I.e., I end up with
	ProjectExplorer
		SAMPLES
			ITEM1-1
			ITEM1-2
I want to get the parent folder into the project, NOT just its contents. I.e., I want to end up with
	ProjectExplorer
		SAMPLES
			/usr/local/SAMPLE1
				ITEM1-1
				ITEM1-2
How do I get that partent folder into the project, instead of just its contents?
Bob
Previous Topic:Alternative to Ctrl-M "maximize editor pane" that maximizes a single editor TAB?
Next Topic:Trigger event once editor is opened
Current Time: Fri Sep 26 20:17:46 EDT 2025
Powered by FUDForum. Page generated in 0.03402 seconds
