Workspace Image path [message #1696399] |
Tue, 26 May 2015 09:52 |
eunjung park Messages: 72 Registered: April 2015 |
Member |
I'm trying to make my own DSL. By the way, I want to change node style into my own images. However, I don't know which directory I should put down the images. Could someone tell the path?
Thank you so much.
Eunjung Park
[Updated on: Tue, 26 May 2015 10:13] Report message to a moderator
Re: Workspace Image [message #1696476 is a reply to message #1696399] |
Tue, 26 May 2015 15:21 |
Hi Eunjung Park,
You might find usefull information on how to customize diagrams with
images in http://melb.enix.org/sirius/customize-diagrams-with-images/
The blog post presents how the user of a Sirius based designer can use
its own image but also ho you as a specifier you can use images in your
specification.
See also [2], [3] and [4].
In the Viewpoint Specification Model editor, several property sections
have a tooltip and a help icon. For the WorkspaceImage style
descriptions, the tooltip of the image path property section indicates:
"The path of the image to use in the form of
/myProjectID/path/to/image.png, if the image is not found in the
workspace it will be looked for in the plugins.".
Le 26/05/2015 11:52, eunjung park a écrit :
> Thank you so much.
> Regards,
> Eunjung Park
Maxime - Obeo
Need professional services for Sirius?
[1] http://melb.enix.org/sirius/customize-diagrams-with-images/
[2]
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#nodes
[3]
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#containers
[4]
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#conditional_styles
Maxime Porhel - Obeo
FUDForum. Page generated in 0.03454 seconds
