Home » Modeling » EMF » [OOMPH] ClassCastException on Installer start
[OOMPH] ClassCastException on Installer start [message #1696362] Tue, 26 May 2015 02:08 Go to next message
Right after starting the Eclipse installer (Windoes x64) I get a ClassCastException:
java.lang.ClassCastException: org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry cannot be cast to org.eclipse.oomph.p2.internal.core.LazyProfileRegistry
	at org.eclipse.oomph.p2.internal.core.AgentImpl.initializeProvisioningAgent(AgentImpl.java:443)
	at org.eclipse.oomph.p2.internal.core.AgentImpl.getProvisioningAgent(AgentImpl.java:472)
	at org.eclipse.oomph.p2.internal.core.AgentImpl.getProfileRegistry(AgentImpl.java:265)
	at org.eclipse.oomph.p2.internal.core.AgentImpl$1.initializeFirstTime(AgentImpl.java:98)
	at org.eclipse.oomph.p2.internal.core.PersistentMap.load(PersistentMap.java:103)
	at org.eclipse.oomph.p2.internal.core.AgentImpl.<init>(AgentImpl.java:131)
	at org.eclipse.oomph.p2.internal.core.AgentManagerImpl.getCurrentAgent(AgentManagerImpl.java:171)
	at org.eclipse.oomph.p2.core.P2Util.getCurrentProvisioningAgent(P2Util.java:87)
	at org.eclipse.oomph.setup.internal.installer.InstallerApplication.run(InstallerApplication.java:64)
	at org.eclipse.oomph.setup.internal.installer.InstallerApplication.start(InstallerApplication.java:271)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
Re: [OOMPH] ClassCastException on Installer start [message #1696365 is a reply to message #1696362] Tue, 26 May 2015 02:16 Go to previous message
Olivier,
There's a bug open about that already.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=468173
(And this is an Oomph issue that should be posted on the Oomph forum,
not the EMF forum.)
> ClassCastException:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
Previous Topic:[EMF Forms] ViewModel generation does not work with classes in packages
Next Topic:[Teneo] problem with update site
Current Time: Thu Sep 25 11:24:52 EDT 2025
Powered by FUDForum. Page generated in 0.07306 seconds
