Home » Eclipse Projects » e(fx)clipse » MDirectMenuItem from DynamicMenuContribution(problem with BaseItemRenderer)
MDirectMenuItem from DynamicMenuContribution [message #1696286] Mon, 25 May 2015 09:36 Go to next message
Bartlomiej Cichocki is currently offline Bartlomiej CichockiFriend
SImple project: sample menu with DynamicMenuContribution:
@AboutToShow
    public void aboutToShow( List< MMenuElement > items )
        MDirectMenuItem directMenuItem = MMenuFactory.INSTANCE.createDirectMenuItem();
        directMenuItem.setLabel( "Label" );
        directMenuItem.setContributionURI( "bundleclass://Test12.app/Test12.app.handlers.HandlerTest" );
        items.add( directMenuItem );
After click it:
Exception in thread "JavaFX Application Thread" java.lang.NullPointerException
	at org.eclipse.fx.ui.workbench.renderers.base.BaseItemRenderer.executeAction(BaseItemRenderer.java:183)
	at org.eclipse.fx.ui.workbench.renderers.base.BaseMenuItemRenderer$1.run(BaseMenuItemRenderer.java:50)
	at org.eclipse.fx.ui.workbench.renderers.fx.DefMenuItemRenderer$MenuItemImpl$2$1.run(DefMenuItemRenderer.java:132)
There is null IEclipseContext i suppose.
Attached sample application.
Or am I doing some wrong?
Re: MDirectMenuItem from DynamicMenuContribution [message #1696287 is a reply to message #1696286] Mon, 25 May 2015 09:46 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
Which version are you using? IIRC this issue was already reported and fixed with 2.0 development branch.
Re: MDirectMenuItem from DynamicMenuContribution [message #1696289 is a reply to message #1696287] Mon, 25 May 2015 09:54 Go to previous messageGo to next message
1.2.0 - sorry. I check it.
Re: MDirectMenuItem from DynamicMenuContribution [message #1696297 is a reply to message #1696289] Mon, 25 May 2015 10:33 Go to previous message
Yeh, in nightly version it works.
Thx
Previous Topic:Internal compiler error with EObjectAdapterProvider
Next Topic:Mars release is approaching
Current Time: Sat Apr 27 04:47:08 GMT 2024
Powered by FUDForum. Page generated in 0.02966 seconds
