Correct way of migration from old version to new one [message #1695784] |
Tue, 19 May 2015 09:18 |
Hello All
I have a tested application that based on version 2.7.3 of xtext. Some part of code is autogenerated by xtext. Configuration file like plugin.xml contains references to 2.7.3 plugins. How can I provide safety migration between two version 2.7.3 and 2.8.x? I would not like create new projects and moving manually my code to new project. Is there more safety way?
Alexander
Re: Correct way of migration from old version to new one [message #1696122 is a reply to message #1695811] |
Fri, 22 May 2015 08:23 |
I did steps that mentioned before. Compilation completed with success. But I cannot run appliccation due to following errors
org.osgi.framework.BundleException: Could not resolve module: com.psl.atom [149]
Unresolved requirement: Require-Bundle: org.eclipse.xtext.xbase; bundle-version="[2.8.2,3.0.0)"; visibility:="reexport"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.xtext.generator; bundle-version="[2.8.2,3.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.emf.codegen.ecore; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.emf.mwe2.launch; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.xtext.builder; bundle-version="[2.8.2,3.0.0)"
-> Bundle-SymbolicName: org.eclipse.xtext.builder; bundle-version="2.8.2.v201504100559"; singleton:="true"
org.eclipse.xtext.builder [43]
Unresolved requirement: Require-Bundle: org.eclipse.xtext.ui; bundle-version="[2.8.0,3.0.0)"
-> Bundle-SymbolicName: org.eclipse.xtext.ui; bundle-version="2.8.2.v201504100559"; singleton:="true"
org.eclipse.xtext.ui [104]
Unresolved requirement: Require-Bundle: org.eclipse.xtext.ide; bundle-version="[2.8.0,3.0.0)"
I checked required library org.eclipse.xtext.ide is located in plugins folder. What is nature of this issue?
[Updated on: Fri, 22 May 2015 09:09] Report message to a moderator
FUDForum. Page generated in 0.02950 seconds
