Home » Eclipse Projects » Sirius » Filter elements according to an attribute
Filter elements according to an attribute [message #1695219] Tue, 12 May 2015 14:34 Go to next message
I have Class called Gate with a property/attribute called type. The type is an enumeration (GateType) which value is either AND, OR or XOR.
When I display the gate, I want to display a different figure according to the type: I want to have a different figure for an OR gate, another different for an AND gate, etc, etc.
I tried to make a conditional Style but it does not seem to work. I tried to put an conditional expression in the conditionalstyle but I have a hard time to access the eobject directly. I tried something like [thisEObject.type = GateType.AND/]
But it seems that thisEObject returns the conditional element and not the eobject. So, I am wondering how can I filter only the Gate object that has the type attribute set to AND or OR. Also, how can I use enumeration values in Accelero expression.
Thanks for any help/hint.
Re: Filter elements according to an attribute [message #1695237 is a reply to message #1695219] Tue, 12 May 2015 21:05 Go to previous messageGo to next message
Making progress. Thanks to http://melb.enix.org/sirius/artificial-container/ I am trying to filter with this expression
[self.eContents()->select(p|p.oclAsType(Gate).type = 0)/]
However, instead of zero, i would then need to find it according my enumeration. So, using something like GateType.OR instead of 0. Any idea how to do it?
Re: Filter elements according to an attribute [message #1695949 is a reply to message #1695237] Wed, 20 May 2015 09:41 Go to previous messageGo to next message
> how to do it?
The concept of OclLitteral does not exist. [1]
But you can manage to do what you want using string comparison.
[self.eContents()->select(p|p.oclAsType(Gate).type.toString() = 'OR ')/]
[1]
http://help.eclipse.org/luna/index.jsp?topic=%2Forg.eclipse.acceleo.doc%2Fpages%2Freference%2Foperations.html&cp=0_3_2
Re: Filter elements according to an attribute [message #1695955 is a reply to message #1695949] Wed, 20 May 2015 10:17 Go to previous message
Hi Julien,
>> how to do it?
> Hi
The qualifier separator in Acceleo MTL is "::" and not "." so the good
way to use the enum literal define in your ecore model is GateType::OR
GateType::AND as you can see on the wiki [1]
[self.eContents()->select(p|p.oclAsType(Gate).type = GateType::OR)/]
You should also use the qualified name of your EClass in your
expressions and domain class: yourpackagename::Gate and
yourpackagename::GateType::OR
Maxime - Obeo
Need professional services for Sirius?
[1]
https://wiki.eclipse.org/Acceleo/FAQ#How_do_I_compare_data_to_an_enumeration_value.3F
Previous Topic:Get selected element in a diagram/table
Next Topic:Eclipse Sirius: How to access ancestors of the EObject of a line mapping?
Current Time: Thu Nov 06 12:36:18 EST 2025
Powered by FUDForum. Page generated in 0.04183 seconds
