Home » Eclipse Projects » Sirius » Empty diagram
Empty diagram [message #1695085] Mon, 11 May 2015 19:55 Go to next message
Dear all,
I tried the 4 minutes tutorial and everything was running without problem. I was able to create the diagram, etc. Now, I would like to do the next step and be able to generate a diagram from my own metamodel. So, I created my meta model, generate the edit/editor code. Then, I made a first model and start to make a viewpoint.
Unfortunately, when trying to show something on the default diagram, nothing appear and the diagram is not created. So, I am trying to figure out what is going on what what I missed.
I mainly have two main questions:
1. How to debug a sirius application? Basically, in that case, how can I try to see what did I do wrong?
2. Is there anything special required in the ecore or genmodel file? As I started my model from scratch, I might have missed something. Any idea/suggestion is appreciated!
Note: my code is available (metamodel, example, sirius design, etc.) is available on https://github.com/juli1/emfta is you want to see what is looks like
Thanks!
Re: Empty diagram [message #1695120 is a reply to message #1695085] Tue, 12 May 2015 03:27 Go to previous messageGo to next message
Le 12/05/2015 01:55, Julien Delange a écrit :
> Dear all,
You can use the validation (Validate context menu on the root of the
VSM). There are here 2 errors:
* The Class edu.cmu.emfta.emfta.Event does not exist.
* A style is missing for EventNode.
Not useful in your case, for the time being,
but you can also use the Interpreter view to varify that the expressions
used in the VSM return the expected result.
There is nothing special required in the ecore or genmodel file. I have
done 3 modifications in your VSM and it's OK now.
* Change the 2 Domain Class: see [1] in documentation for information
about typaes name
* Add a style on the EventNode
I have made a pull request corresponding to these changes [2]
> looks like
> Thanks!
[1]
http://www.eclipse.org/sirius/doc/specifier/general/Specifying_Viewpoints.html#type_names
[2] https://github.com/juli1/emfta/pull/1
Laurent Redor - Obeo
Need professional services for Sirius?
Re: Empty diagram [message #1695164 is a reply to message #1695120] Tue, 12 May 2015 08:18 Go to previous messageGo to next message
I did not expect such a help and quick support! I tried the fixed but it does not work. Also, when I try to validate the model and I put bad class names, the model still validates even if I am using a non-existing class.
In fact, after running in debug mode, I got the following trace (see below). Anything I did wrong?
!ENTRY org.eclipse.emf.validation 2 80 2015-05-12 08:17:24.845
!MESSAGE The constraint "org.eclipse.sirius.constraints.ValidInterpretedExpressionConstraint" is disabled. It will not be evaluated.
!STACK 0
at org.eclipse.sirius.common.tools.internal.interpreter.FeatureInterpreter.getCurrentElementType(FeatureInterpreter.java:160)
at org.eclipse.sirius.common.tools.internal.interpreter.FeatureInterpreter.validateExpression(FeatureInterpreter.java:117)
at org.eclipse.sirius.tools.internal.validation.description.constraints.ValidInterpretedExpressionConstraint.checkExpression(ValidInterpretedExpressionConstraint.java:83)
at org.eclipse.sirius.tools.internal.validation.description.constraints.ValidInterpretedExpressionConstraint.validate(ValidInterpretedExpressionConstraint.java:56)
at org.eclipse.emf.validation.internal.util.JavaConstraintParser$ConstraintAdapter.validate(JavaConstraintParser.java:80)
at org.eclipse.emf.validation.internal.service.AbstractValidator.evaluateConstraints(AbstractValidator.java:241)
at org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:264)
at org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:211)
at org.eclipse.emf.validation.internal.service.BatchValidator.doValidate(BatchValidator.java:149)
at org.eclipse.emf.validation.internal.service.AbstractValidator.validate(AbstractValidator.java:147)
at org.eclipse.emf.validation.internal.service.AbstractValidator.validate(AbstractValidator.java:126)
at org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:117)
at org.eclipse.sirius.tools.internal.validation.EValidatorAdapter.validate(EValidatorAdapter.java:80)
at org.eclipse.emf.ecore.util.Diagnostician.doValidate(Diagnostician.java:171)
at org.eclipse.emf.edit.ui.action.ValidateAction$3.doValidate(ValidateAction.java:309)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:158)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:137)
at org.eclipse.emf.edit.ui.action.ValidateAction.validate(ValidateAction.java:264)
at org.eclipse.emf.edit.ui.action.ValidateAction$1.run(ValidateAction.java:176)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:122)
Retrieving for: DatatypeDefinitionString
Constant: DatatypeDefinitionString
Not replacing default for DatatypeDefinitionString with LinewrapConfigurationImpl, as there is already a default: org.eclipse.rmf.reqif10.pror.presentation.linewrap.impl.LinewrapConfigurationImpl
Re: Empty diagram [message #1695172 is a reply to message #1695164] Tue, 12 May 2015 09:19 Go to previous messageGo to next message
Follow up. I am also trying to do the tutorial again and have some issue. I got the following stack trace. Is there any special version I should try? For now, I am using the last Luna build.
Thansk!
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4441)
at org.eclipse.swt.SWT.error(SWT.java:4356)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:139)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3774)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3412)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:175)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:390)
at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2.run(RefactoringWizardDialog2.java:331)
at org.eclipse.ltk.ui.refactoring.RefactoringWizard.internalPerformFinish(RefactoringWizard.java:637)
at org.eclipse.ltk.ui.refactoring.UserInputWizardPage.performFinish(UserInputWizardPage.java:153)
at org.eclipse.ltk.ui.refactoring.resource.DeleteResourcesWizard$DeleteResourcesRefactoringConfigurationPage.performFinish(DeleteResourcesWizard.java:202)
at org.eclipse.ltk.ui.refactoring.RefactoringWizard.performFinish(RefactoringWizard.java:710)
at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2.okPressed(RefactoringWizardDialog2.java:455)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:466)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:619)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4454)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1388)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3799)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3409)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:832)
at org.eclipse.jface.window.Window.open(Window.java:808)
at org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperation$1.run(RefactoringWizardOpenOperation.java:187)
at org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperation.run(RefactoringWizardOpenOperation.java:202)
at org.eclipse.ltk.ui.refactoring.RefactoringWizardOpenOperation.run(RefactoringWizardOpenOperation.java:122)
at org.eclipse.ltk.internal.ui.refactoring.actions.DeleteResourcesHandler.execute(DeleteResourcesHandler.java:40)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:294)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:247)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:229)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:149)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommandInContext(LegacyHandlerService.java:396)
at org.eclipse.ui.internal.ide.actions.LTKLauncher.runCommand(LTKLauncher.java:95)
at org.eclipse.ui.internal.ide.actions.LTKLauncher.openDeleteWizard(LTKLauncher.java:47)
at org.eclipse.ui.actions.DeleteResourceAction.run(DeleteResourceAction.java:474)
at org.eclipse.jdt.internal.ui.refactoring.reorg.DeleteAction.run(DeleteAction.java:197)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:519)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
at org.eclipse.ui.part.MultiPageEditorPart.deactivateSite(MultiPageEditorPart.java:946)
at org.eclipse.ui.part.MultiPageEditorPart.dispose(MultiPageEditorPart.java:513)
at org.eclipse.sirius.editor.editorPlugin.SiriusEditor.dispose(SiriusEditor.java:1320)
at org.eclipse.sirius.editor.tools.internal.presentation.CustomSiriusEditor.dispose(CustomSiriusEditor.java:370)
at org.eclipse.sirius.editor.editorPlugin.SiriusEditor$3$1.run(SiriusEditor.java:410)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:136)
... 77 more
Loading ECPProjectManage
Re: Empty diagram [message #1695199 is a reply to message #1695164] Tue, 12 May 2015 11:00 Go to previous messageGo to next message
Oups sorry, I've used my current dev environment to test your model and
to make the changes. This corresponds to the next Sirius 3.0.0 that will
be released with Eclipse Mars.
There are improvment on validation in this version. This, perhaps,
explains the difference with your environment.
But, if you use the pull request as starting point, you should have a
first operational diagram.
Le 12/05/2015 14:18, Julien Delange a écrit :
> class.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Empty diagram [message #1695200 is a reply to message #1695172] Tue, 12 May 2015 11:06 Go to previous messageGo to next message
This stack corresponds to this bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=433859
> Thansk!
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 77 more
Re: Empty diagram [message #1695215 is a reply to message #1695200] Tue, 12 May 2015 13:24 Go to previous message
After updating to the latest nightly, everything is working
Previous Topic:examples for tables
Next Topic:Unable to create view point selection
Current Time: Mon Jun 23 12:56:44 EDT 2025
Powered by FUDForum. Page generated in 0.33975 seconds
