Re: show provide/required interfaces in component diagram [message #1745391 is a reply to message #1695065] |
Mon, 10 October 2016 06:44 |
Tristan Faure Messages: 460 Registered: July 2009 |
Hello
I have tested Requirement Diagram in Papyrus Neon SR 1
I have some problems I would like to know if it is "normal" :
- "display as lollipop" :
the orientation of the lollipop is very hard to define and it is not clear if the interface is realized or used when several connectors are connected
- interface creation:
If I create a component. I can create a component inside but not an interface. the only possibility I have is creating the interface outside, moving it inside the component using the model explorer and then move it in the diagram ...
FUDForum. Page generated in 0.03618 seconds
