Home » Eclipse Projects » EGit / JGit » Commiting project(Committing project to git picks up previous project's working directory)
Commiting project [message #1693968] Wed, 29 April 2015 11:58 Go to next message
I have 4 different projects which are linked to different git repositories in eclipse. I have a strange issue. Lets say I have project p1, p2, p3, p4 in eclispe, in the same order. Whenever I try to commit project p3 (using Team > Commit), egit picks the working directory of the p2 project in the order. This happens for all the projects. But if I disconnect all the previous projects from git, then I am able to commit the correct working directory. Could you fix this?
Re: Commiting project [message #1694269 is a reply to message #1693968] Mon, 04 May 2015 02:45 Go to previous message
Never saw this kind of problem. There must be something special with your setup. Are your projects or git repositories nested? Means: is one repositories root directory below another repositories root folder? Same question for the projects (The location of your .project files)? Is one .project file located in a folder and one of the parent folders contain another .project file? Maybe you could add a list of locations of your .project files and your .git folders.
Previous Topic:Jgit diff and triple dot
Next Topic:Finding a merge commit with JGit
Current Time: Sat Nov 08 01:46:42 EST 2025
Powered by FUDForum. Page generated in 0.05017 seconds
