Home » Eclipse Projects » EclipseLink » Moxy marshalling removes xsi namespace definitions(Moxy marshalling and unmarshalling modifies XML definition and removes xsi attribute)
Moxy marshalling removes xsi namespace definitions [message #1693411] Thu, 23 April 2015 19:30
Jaw-WS CXF service creates XML output that has missing xsi namespace. This only happens with Moxy and not with JaxB
Here is the overview:
POJOS are generated from WSDL and XSDs.
javax.xml.bind.context.factory=org.eclipse.persistence.jaxb.JAXBContextFactory property has been defined in Jaxb.properties file. This is ensuring that eclipselink moxy is used during runtime for marshalling/unmarshalling.
We are using Apache CXF Jax-Ws for our Soap services.
Sample xml returned from downstream service is shown below. This xml is well formed:
<message:RetrieveOrderResponse xmlns:common="urn:xyz:om:common:defn:v1" xmlns:message="urn:xyz:om:order:messages:v1" xmlns:xsd="www.w3.org/2001/XMLSchema" xmlns:xsi="www.w3.org/2001/XMLSchema-instance">
 <common:MessageInfo CreateDateTime="2015-04-17T13:13:36.819-07:00" MessageGUID="d8ad2956-ff69-45ff-9d57-c30dc50569a1" TransactionGUID="a772169a-b138-40e7-8d16-ca86b68d38b8">
    <common:DebugTraceBoolean>true</common:DebugTraceBoolean>
 </common:MessageInfo>
 <common:MessageStatus>
    <common:Status>Success</common:Status>
 </common:MessageStatus>
 <common:OrderList>
    <common:Order>
       <common:OrderLineList>
          <common:OrderLine>
             <common:OrderLineData namespace="urn:xyz:e3:data:abc:types:v1" type="xyzProduct">
                <ns2:xyzProduct xmlns:datatype="urn:xyz:om:supply:datatype:defn:v1" xmlns:finance="urn:xyz:e3:data:financetypes:defn:v4" xmlns:internal="urn:xyz:cc:es:order:internal" xmlns:min="xalan://org.jaxen.function.MinDateTimeFunction" xmlns:ns2="urn:xyz:e3:data:abc:types:v1" xmlns:ns3="urn:xyz:e3:data:basetypes:defn:v4" xmlns:ns4="urn:xyz:e3:data:financetypes:defn:v4" xmlns:ns5="urn:xyz:e3:data:timetypes:defn:v4" xmlns:ns6="urn:xyz:e3:data:messagetypes:defn:v5" xmlns:ns7="urn:xyz:e3:data:placetypes:defn:v4" xmlns:ns8="urn:xyz:om:supply:messages:defn:v1">
                   <ns2:abcProduct>
                      <ns2:DiningSeatingInformation>
                         <BookingStatusCode xsi:nil="true"/>
                         <DinSeatingCode xsi:nil="true"/>
                      </ns2:DiningSeatingInformation>
                   </ns2:abcProduct>
                </ns2:xyzProduct>
             </common:OrderLineData>
          </common:OrderLine>
       </common:OrderLineList>
    </common:Order>
 </common:OrderList>
We call the downstream service and unmarshall the response into a POJO.
POJO is then sent in service Response. On the client side the xml received from service client is missing
namespace definitions. Hence when client tries to unmarshall, following exception is thrown
Because of this unmarshalling on client side fails with error: null:Exception [EclipseLink-25004] (Eclipse Persistence Services - 2.6.0.v20150309-bf26070): org.eclipse.persistence.exceptions.XMLMarshalException Exception Description: An error occurred unmarshalling the document Internal Exception: com.ctc.wstx.exc.WstxParsingException: Undeclared namespace prefix "xsi" (for attribute "nil") at [row,col {unknown-source}]: [1,7692]
Has anyone encountered similar issue where MOXY is giving trouble with xsi namespace definition during marshalling unmarshalling?
Thanks in advance for your help.
[Updated on: Mon, 27 April 2015 02:18] by Moderator
Previous Topic:Eclipselink runs in debug but fails in deployed jar - IllegalArgumentException: eclipselink.tolerate
Next Topic:Workbench not shiped in EclipseLink2.6
Current Time: Fri Nov 07 01:46:56 EST 2025
Powered by FUDForum. Page generated in 0.05736 seconds
