Home » Eclipse Projects » EclipseLink » Eclipselink connection error (trying to create too many connections)(Eclipselink connection using DataSource)
Eclipselink connection error (trying to create too many connections) [message #1693226] Wed, 22 April 2015 09:33 Go to next message
Hi, we are currently migrating Toplink to Eclipselink 2.4.2 in our application which is running on Websphere 8. At the server startup I can see that Eclipselink is able to connect to Datasource from this log.
[30/03/15 16:28:05:056 BST] 00000009 SystemOut O [EL Config]: connection: 2015-03-30 16:28:05.055--connecting(DatabaseLogin(
platform=>Oracle11Platform
user name=> "null"
connector=>JNDIConnector datasource name=>jdbc/xxxTabDataSource
[30/03/15 16:28:05:056 BST] 00000009 SystemOut O [EL Config]: connection: 2015-03-30 16:28:05.056--Connected: jdbc:oracle:thin:@XXX:000:XXX
User: XXX_PRX
Database: Oracle Version: Oracle Database 11g Enterprise Edition Release 11.2.0.4.0 - 64bit Production
With the Partitioning option
Driver: Oracle JDBC driver Version: 11.2.0.2.0
[30/03/15 16:28:05:134 BST] 00000009 SystemOut O [EL Info]: connection: 2015-03-30 16:28:05.134-- xxxSession login successful
When running any query, the application seems to be trying to create too many connections and finally failing with either Stackflow or Pool allocation error. In the logs we can see that multiple connections for the same query
[30/03/15 16:28:05:056 BST] 0000002d SystemOut O [EL Fine]: sql: 2015-04-22 13:18:06.065--Connection(1414240713)--SELECT USER_ID, BRAND_ACRONYM, DEPARTMENT_CODE, EXPIRY_DATE, IS_SUPER_USER, LAST_LOGIN_DATE, PII_VISIBILITY, ROLE_ID, START_DATE, USER_EMAILID, USER_FNAME, USER_FUNCTION, USER_SNAME, USER_STATUS, USER_TELEPHONE FROM XYZ.USER_PROFILE WHERE (USER_ID = ?)
bind => [XXXXXX]
[30/03/15 16:28:05:056 BST] 0000002d SystemOut O [EL Fine]: sql: 2015-04-22 13:18:06.071--Connection(-259746999)--SELECT USER_ID, BRAND_ACRONYM, DEPARTMENT_CODE, EXPIRY_DATE, IS_SUPER_USER, LAST_LOGIN_DATE, PII_VISIBILITY, ROLE_ID, START_DATE, USER_EMAILID, USER_FNAME, USER_FUNCTION, USER_SNAME, USER_STATUS, USER_TELEPHONE FROM XYZ.USER_PROFILE WHERE (USER_ID = ?)
bind => [XXXXXX]
....... (the above repeated for 50 times)
The final error is either this one ..
[30/03/15 16:28:05:056 BST] 0000002d ServletWrappe E com.ibm.ws.webcontainer.servlet.ServletWrapper service Uncaught service() exception thrown by servlet action: java.lang.StackOverflowError
at com.ibm.ejs.j2c.PoolManager.reserve(PoolManager.java:2609)
at com.ibm.ejs.j2c.ConnectionManager.allocateMCWrapper(ConnectionManager.java:1500)
at com.ibm.ejs.j2c.ConnectionManager.allocateConnection(ConnectionManager.java:1012)
at com.ibm.ws.rsadapter.jdbc.WSJdbcDataSource.getConnection(WSJdbcDataSource.java:669)
at com.ibm.ws.rsadapter.jdbc.WSJdbcDataSource.getConnection(WSJdbcDataSource.java:636)
at org.eclipse.persistence.sessions.JNDIConnector.connect(JNDIConnector.java:123)
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162)
or
at java.util.Hashtable$HashEnumIterator.nextElement(Hashtable.java:808)
at java.util.PropertyPermissionCollection.implies(PropertyPermissionCollection.java:69)
at org.eclipse.osgi.internal.permadmin.PermissionInfoCollection.implies(PermissionInfoCollection.java:80)
at org.eclipse.osgi.internal.permadmin.BundlePermissions.implies(BundlePermissions.java:59)
at java.security.ProtectionDomain.implies(ProtectionDomain.java:213)
at java.security.AccessController.checkPermission(AccessController.java:173)
at java.lang.SecurityManager.checkPermission(SecurityManager.java:544)
at com.ibm.ws.security.core.SecurityManager.checkPermission(SecurityManager.java:208)
at java.lang.SecurityManager.checkPropertyAccess(SecurityManager.java:1297)
at java.lang.System.getProperty(System.java:408)
at java.lang.System.getProperty(System.java:392)
at sun.security.action.GetPropertyAction.run(GetPropertyAction.java:86)
Could you please help in identifying the root cause of the issue. The application was working correctly when we were using Toplink. We moved all the configuration data to eclipselink.
Ravi
Re: Eclipselink connection error (trying to create too many connections) [message #1693241 is a reply to message #1693226] Wed, 22 April 2015 10:58 Go to previous messageGo to next message
It would be helpful if you posted the full stacktrace.
Rick
Re: Eclipselink connection error (trying to create too many connections) [message #1693324 is a reply to message #1693241] Thu, 23 April 2015 04:46 Go to previous messageGo to next message
Hi Thanks for the response. the full stack trace is very long, hence I was hesitant to post it earlier. Here is the full stack trace.
[4/22/15 13:18:06:465 BST] 0000002d SystemOut O [EL Fine]: sql: 2015-04-22 13:18:06.465--Connection(-1417456453)--SELECT USER_ID, BRAND_ACRONYM, DEPARTMENT_CODE, EXPIRY_DATE, IS_SUPER_USER, LAST_LOGIN_DATE, PII_VISIBILITY, ROLE_ID, START_DATE, USER_EMAILID, USER_FNAME, USER_FUNCTION, USER_SNAME, USER_STATUS, USER_TELEPHONE FROM USER_PROFILE WHERE (USER_ID = ?)
bind => [XYZ]
[4/22/15 13:18:06:644 BST] 0000002d ServletWrappe E com.ibm.ws.webcontainer.servlet.ServletWrapper service Uncaught service() exception thrown by servlet action: java.lang.StackOverflowError
at sun.security.action.GetPropertyAction.run(GetPropertyAction.java:51)
at java.security.AccessController.doPrivileged(AccessController.java:273)
at java.io.PrintWriter.<init>(PrintWriter.java:89)
at java.io.PrintWriter.<init>(PrintWriter.java:73)
at com.ibm.ejs.ras.StreamEvent6.convertToString(StreamEvent6.java:298)
at com.ibm.ws.logging.object.WsLogRecordFactory.createWsLogRecord(WsLogRecordFactory.java:401)
at com.ibm.ejs.ras.Tr.logToWsHandlers(Tr.java:1720)
at com.ibm.ejs.ras.Tr.systemOut(Tr.java:1022)
at com.ibm.ejs.ras.SystemOutStream.dispatchEvent(SystemOutStream.java:393)
at com.ibm.ejs.ras.SystemStream.write(SystemStream.java:298)
at com.ibm.ejs.ras.SystemOutStream.write(SystemOutStream.java:80)
at sun.nio.cs.StreamEncoder$CharsetSE.writeBytes(StreamEncoder.java:355)
at sun.nio.cs.StreamEncoder$CharsetSE.implFlushBuffer(StreamEncoder.java:425)
at sun.nio.cs.StreamEncoder$CharsetSE.implFlush(StreamEncoder.java:429)
at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:175)
at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:274)
at java.io.BufferedWriter.flush(BufferedWriter.java:247)
at java.io.PrintWriter.flush(PrintWriter.java:287)
at org.eclipse.persistence.logging.DefaultSessionLog.log(DefaultSessionLog.java:144)
at org.eclipse.persistence.internal.sessions.AbstractSession.log(AbstractSession.java:3246)
at org.eclipse.persistence.internal.sessions.AbstractSession.log(AbstractSession.java:4364)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:583)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:537)
at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1805)
at org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:566)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:207)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:193)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectOneRow(DatasourceCallQueryMechanism.java:668)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRowFromTable(ExpressionQueryMechanism.java:2769)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRow(ExpressionQueryMechanism.java:2722)
at org.eclipse.persistence.queries.ReadObjectQuery.executeObjectLevelReadQuery(ReadObjectQuery.java:453)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1150)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:852)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1109)
at org.eclipse.persistence.queries.ReadObjectQuery.execute(ReadObjectQuery.java:421)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1197)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2879)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1607)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1589)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1540)
at org.eclipse.persistence.internal.sessions.AbstractSession.checkAndRefreshInvalidObject(AbstractSession.java:1051)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.cloneAndRegisterObject(UnitOfWorkImpl.java:981)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildWorkingCopyCloneNormally(ObjectBuilder.java:739)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObjectInUnitOfWork(ObjectBuilder.java:676)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:609)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:564)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:777)
at org.eclipse.persistence.queries.ReadObjectQuery.registerResultInUnitOfWork(ReadObjectQuery.java:787)
at org.eclipse.persistence.queries.ReadObjectQuery.executeObjectLevelReadQuery(ReadObjectQuery.java:460)
Re: Eclipselink connection error (trying to create too many connections) [message #1693342 is a reply to message #1693324] Thu, 23 April 2015 07:58 Go to previous messageGo to next message
Are you able to easily recreate this problem by executing the same query every time? If so, what is the query that you're executing and what does the Entity look like?
Re: Eclipselink connection error (trying to create too many connections) [message #1693375 is a reply to message #1693342] Thu, 23 April 2015 11:23 Go to previous messageGo to next message
Yes we are able to recreate the issue easily. This is the first query of the application(Checking user access level). So I presume this issue will occur with any query. This is the query
bind => [XYZ]
This is standard user information table. The above query was working fine when we were using Toplink.
Re: Eclipselink connection error (trying to create too many connections) [message #1693380 is a reply to message #1693375] Thu, 23 April 2015 11:29 Go to previous messageGo to next message
Have you tried to run your test in a JSE environment? That would help narrow in on whether this is a problem with the app server or EclipseLink.
Re: Eclipselink connection error (trying to create too many connections) [message #1693511 is a reply to message #1693380] Fri, 24 April 2015 11:47 Go to previous messageGo to next message
Thanks for the suggestion. We will try it
Re: Eclipselink connection error (trying to create too many connections) [message #1693525 is a reply to message #1693511] Fri, 24 April 2015 14:20 Go to previous messageGo to next message
The problem seems to be with invalidation settings, as the object is being invalidated somehow while it is being built, forcing it to constantly be refreshed over and over until you run out of stack. Since you mention this worked in TopLink, check out the descriptor in the Toplink project and compare it to the EclipseLink project and manually verify that everything was converted as you expect with special attention to any refresh or invalidation options. Oracle support might be the best option to help assuming you have a support contract, otherwise you may need to post a lot more information to help isolate what is going wrong, and it is usually easier to get help on the forums if you can run against the latest EclipseLink version (2.6 maybe), so that the stack trace is current and rules out any previously fixed issues.
icon14.gif  Re: Eclipselink connection error (trying to create too many connections) [message #1693677 is a reply to message #1693525] Mon, 27 April 2015 08:59 Go to previous messageGo to next message
Many Many Thanks Chris Delahunt. Your suggestion worked. Root cause is indeed incorrect cache invalidation setting. For some objects we have
<cache-invalidation-policy xsi:type="time-to-live-cache-invalidation-policy">
<time-to-live>0</time-to-live>
</cache-invalidation-policy>
The above was working in Toplink. But failing in eclipselink. I increased the time-to-live value and the application is working. Thanks Rick Curtis for looking into this.
Re: Eclipselink connection error (trying to create too many connections) [message #1694197 is a reply to message #1693677] Fri, 01 May 2015 16:51 Go to previous message
What is the default value?
Thanks.
Previous Topic:EclipseLink 2.5 and Websphere 8.5.5: "JVMVRFY013 class loading constraint violated" Error
Next Topic:Can we have multiple dataSources to single database
Current Time: Wed Sep 03 04:13:47 EDT 2025
Powered by FUDForum. Page generated in 0.04274 seconds
