Home » Language IDEs » PHP Development Tools (PDT) » Content assist semi-broken since February 2015 update(Content assist semi-broken since February 2015 update)
Content assist semi-broken since February 2015 update [message #1692774] Fri, 17 April 2015 20:07 Go to next message
Hello.
Content assist seems to be broken for $this and sometimes for other variables.
I am getting the stacktrace below. Is there any way I can fix this?
Thanks.
org.eclipse.e4.core.di.InjectionException: java.lang.NoSuchMethodError: org.eclipse.php.internal.ui.editor.contentassist.PHPCompletionProposalLabelProvider.getReturnTypeSeparator()Ljava/lang/String;
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:285)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:504)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:555)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:376)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:322)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:84)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1554)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1391)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1416)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1401)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1428)
	at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.java:829)
	at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control.java:3236)
	at org.eclipse.swt.widgets.Composite.gtk_key_press_event(Composite.java:758)
	at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:2096)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:5467)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4569)
	at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
	at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:8756)
	at org.eclipse.swt.widgets.Display.eventProc(Display.java:1243)
	at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
	at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2302)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3361)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.NoSuchMethodError: org.eclipse.php.internal.ui.editor.contentassist.PHPCompletionProposalLabelProvider.getReturnTypeSeparator()Ljava/lang/String;
	at org.eclipse.php.internal.ui.editor.contentassist.PHPCompletionProposalLabelProvider.createFieldProposalLabel(PHPCompletionProposalLabelProvider.java:194)
	at org.eclipse.php.internal.ui.editor.contentassist.PHPCompletionProposalCollector.createFieldProposal(PHPCompletionProposalCollector.java:346)
	at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalCollector.createScriptCompletionProposal(ScriptCompletionProposalCollector.java:465)
	at org.eclipse.php.internal.ui.editor.contentassist.PHPCompletionProposalCollector.createScriptCompletionProposal(PHPCompletionProposalCollector.java:121)
	at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalCollector.processUnprocessedProposal(ScriptCompletionProposalCollector.java:342)
	at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalCollector.processUnprocessedProposals(ScriptCompletionProposalCollector.java:300)
	at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalCollector.getScriptCompletionProposals(ScriptCompletionProposalCollector.java:282)
	at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalComputer.computeScriptCompletionProposals(ScriptCompletionProposalComputer.java:193)
	at org.eclipse.dltk.ui.text.completion.ScriptCompletionProposalComputer.computeCompletionProposals(ScriptCompletionProposalComputer.java:240)
	at org.eclipse.dltk.ui.text.completion.CompletionProposalComputerDescriptor.computeCompletionProposals(CompletionProposalComputerDescriptor.java:342)
	at org.eclipse.dltk.ui.text.completion.CompletionProposalCategory.computeCompletionProposals(CompletionProposalCategory.java:276)
	at org.eclipse.dltk.ui.text.completion.ContentAssistProcessor.collectProposals(ContentAssistProcessor.java:291)
	at org.eclipse.dltk.ui.text.completion.ContentAssistProcessor.computeCompletionProposals(ContentAssistProcessor.java:247)
	at org.eclipse.wst.sse.ui.internal.contentassist.CompoundContentAssistProcessor.computeCompletionProposals(CompoundContentAssistProcessor.java:127)
	at org.eclipse.jface.text.contentassist.ContentAssistant.computeCompletionProposals(ContentAssistant.java:1839)
	at org.eclipse.jface.text.contentassist.CompletionProposalPopup.computeProposals(CompletionProposalPopup.java:566)
	at org.eclipse.jface.text.contentassist.CompletionProposalPopup.access$16(CompletionProposalPopup.java:563)
	at org.eclipse.jface.text.contentassist.CompletionProposalPopup$2.run(CompletionProposalPopup.java:498)
	at org.eclipse.jface.text.contentassist.CompletionProposalPopup.showProposals(CompletionProposalPopup.java:492)
	at org.eclipse.jface.text.contentassist.ContentAssistant.showPossibleCompletions(ContentAssistant.java:1665)
	at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.doOperation(StructuredTextViewer.java:488)
	at org.eclipse.php.internal.ui.editor.PHPStructuredTextViewer.doOperation(PHPStructuredTextViewer.java:298)
	at org.eclipse.ui.texteditor.ContentAssistAction$1.run(ContentAssistAction.java:82)
	at org.eclipse.ui.texteditor.ContentAssistAction.run(ContentAssistAction.java:80)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:499)
	at org.eclipse.jface.commands.ActionHandler.execute(ActionHandler.java:119)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	... 53 more
Re: Content assist semi-broken since February 2015 update [message #1692778 is a reply to message #1692774] Sat, 18 April 2015 04:08 Go to previous messageGo to next message
Can you update dltk: http://download.eclipse.org/technology/dltk/updates-dev/5.1.1/
Re: Content assist semi-broken since February 2015 update [message #1692788 is a reply to message #1692778] Sat, 18 April 2015 10:36 Go to previous messageGo to next message
Dawid Pakula wrote on Sat, 18 April 2015 08:08
Can you update dltk: [site blacklisted because I have fewer than 5 edits]
Thank you; that did fix it. For future reference, is there a way that I should know the URL for the latest DLTK when updating?
Re: Content assist semi-broken since February 2015 update [message #1692859 is a reply to message #1692788] Mon, 20 April 2015 05:42 Go to previous message
DLTK haven't "latest" repo like we. If you are synced with eclipse, you should get latest dltk together with latest PDT (Luna simulates release now).
Here you can find all DLTK versions (numbers only): https://projects.eclipse.org/projects/technology.dltk
Previous Topic:Eclipse project with multiple developers in same folder
Next Topic:Quick Outline stopped working
Current Time: Sun Nov 09 15:16:03 EST 2025
Powered by FUDForum. Page generated in 0.04094 seconds
