Nabula Nattable using in Rich Client Platform When open in new tab click on menu item select [message #1692674] |
Fri, 17 April 2015 10:14 |
eclipse.buildId=unknown
java.version=1.8.0_40
Framework arguments: -application RCPAppThree.application
Command-line arguments: -application RCPAppThree.application -data D:\Lalit\Lalit_workspace/../runtime-RCPAppThree.application -dev file:D:/Lalit/Lalit_workspace/.metadata/.plugins/org.eclipse.pde.core/RCPAppThree.application/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench 4 0 2015-04-17 15:28:06.169
!MESSAGE Unable to create class 'org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor' from bundle '47'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.ExceptionInInitializerError
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:62)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:888)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:869)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:120)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:337)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:258)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:127)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:983)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:662)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:95)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:156)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4734)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:218)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:488)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:454)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:705)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1142)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3210)
at org.eclipse.ui.internal.WorkbenchPage.access$23(WorkbenchPage.java:3125)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:3107)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3102)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3066)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3047)
at rcpappthree.tableview.UserTableCommand.execute(UserTableCommand.java:22)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:294)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:247)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:229)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:149)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:825)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:701)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$6(HandledContributionItem.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:613)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at rcpappthree.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Caused by: java.lang.ExceptionInInitializerError
at rcpappthree.tableview.ApplicationDeta.createPartControl(ApplicationDeta.java:135)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:141)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:99)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:327)
... 93 more
Caused by: org.apache.commons.logging.LogConfigurationException: The chosen LogFactory implementation does not extend LogFactory. Please check your configuration. (Caused by java.lang.ClassCastException: org.apache.commons.logging.impl.LogFactoryImpl cannot be cast to org.apache.commons.logging.LogFactory)
at org.apache.commons.logging.LogFactory$2.run(LogFactory.java:574)
at org.apache.commons.logging.LogFactory.newFactory(LogFactory.java:517)
at org.apache.commons.logging.LogFactory.getFactory(LogFactory.java:316)
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java:351)
at org.eclipse.nebula.widgets.nattable.data.ReflectiveColumnPropertyAccessor.<clinit>(ReflectiveColumnPropertyAccessor.java:34)
... 102 more
Caused by: java.lang.ClassCastException: org.apache.commons.logging.impl.LogFactoryImpl cannot be cast to org.apache.commons.logging.LogFactory
at org.apache.commons.logging.LogFactory$2.run(LogFactory.java:531)
... 107 more
Lalit
FUDForum. Page generated in 0.04298 seconds
