Home » Eclipse Projects » Eclipse Platform » How to add command contribution plugin to the Eclipse "Quick Access" for all perspectives?
How to add command contribution plugin to the Eclipse "Quick Access" for all perspectives? [message #1692365] Wed, 15 April 2015 06:46 Go to next message
I have a command contribution plugin. However it's visible in the "Quick Access" only when I make it available via Window -> Customize Perspective -> Command Groups Availability. Is it possible to make it available for the "Quick Access" for all perspectives regardless of the "Command Group Availability" ?
Re: How to add command contribution plugin to the Eclipse "Quick Access" for all perspecti [message #1698579 is a reply to message #1692365] Tue, 16 June 2015 09:43 Go to previous message
The gist & solution to the problem are the following:
Gist of the issue
The command is contributed as an actionSet, which ties it to be active in a perspective (it will also add it to the menus and toolbars)
Solution
Need to write a command and make sure the actionSet action sets the - definitionId to the commandId. Then write a defaultHandler for the command, the one that will work in the general case (by default it will add the command to the Quick Access regardless of the perspective).
Previous Topic:Incorporating new behaviors into Release Note
Next Topic:DnD PluginTransfer from Navigator
Current Time: Wed Aug 06 00:41:59 EDT 2025
Powered by FUDForum. Page generated in 0.06483 seconds
