Hudson Integration with ClearCase on linux box [message #1692209] |
Tue, 14 April 2015 10:44 |
Venugopal Kodumagulla Messages: 3 Registered: April 2015 |
I am trying to Hudson environment on Linux operating system and configuring ClearCase.
I have configured config spec details to create a snapshot view.
When I start the build, the hudson server is trying to cleartoo command with the username "hudson" which doesn't exist and job is getting failed with below Exception.
workspace] $ /opt/ibm/RationalSDLC/clearcase/linux_x86/bin/cleartool mkview -snapshot -tag hudson_master_Test1-Build_hudson view
Selected Server Storage Location "view_storage".
cleartool: Error: Unable to create directory "/scfs3/vws_u/hudson/view": Permission denied.
FATAL: Base ClearCase failed. exit code=1
java.io.IOException: cleartool did not return the expected exit code. Command line="mkview -snapshot -tag hudson_master_Test1-Build_hudson view", actual exit code=1
But I want to run the cleartool command with different user from hudson build.
Can you guide mefor the right configuration in this regard.
Thanks, Venugopal
FUDForum. Page generated in 0.02685 seconds
