Home » Eclipse Projects » EGit / JGit » Compare versions of a file before merging(How to see the changes in a file side by side)
Compare versions of a file before merging [message #1691385] Mon, 06 April 2015 17:01 Go to next message
I'm developing a git comparison tool integrated with another one developed by the company I work. I want to do pretty much what "team -> merge tool" does in Eclipse, i.e. comparing my last commit with the incoming one. I took a look at the EGit code but it's very complex for what I need.
In svn it's pretty easy because it creates two files (the old and the new versions), but in git it's necessary to get the information somewhere.
[Updated on: Mon, 06 April 2015 17:02] by Moderator
Re: Compare versions of a file before merging [message #1691659 is a reply to message #1691385] Wed, 08 April 2015 15:02 Go to previous messageGo to next message
Ok, it seems working if a use FETCH_HEAD as my remote change without forcing a new fetch. I achieved the "two side" merger. My merge tool only accepts that the user update their current version applying the new changes. But then, how do I say "my file is merged"?
Re: Compare versions of a file before merging [message #1691889 is a reply to message #1691659] Fri, 10 April 2015 06:18 Go to previous message
In git you typically tell that "my file is merged" by adding new content to the index. JGits AddCommand helps you.
Previous Topic:Egit shows differences that don't exist
Next Topic:Import function: Git option not available
Current Time: Sat Nov 08 01:51:05 EST 2025
Powered by FUDForum. Page generated in 0.04012 seconds
