Re: [ECP] Additional label alignment option "Top"? [message #1691219 is a reply to message #1690959] |
Fri, 03 April 2015 14:06 |
Jonas Helming Messages: 699 Registered: July 2009 |
I assume you are talking about EMF Forms, right? You are right, we
should reconsider the options available for the label. Another option
would be to add an option "default", which leaves the label position to
th renderer. This would fit the current state. Could you open a Bug
Report to discuss this?
Thank you and best regards
Jonas
Am 01.04.2015 um 12:00 schrieb Matthias Juchmes:
> Hello,
> we are working on the ECP-Implementation for Vaadin. In Vaadin, labels
> (captions) are displayed at the top by default, with the option to
> display them on the left using a FormLayout (or none at all, of course).
> Examples for the AngularJS renderer also show labels at the top.
> The ECP model provides the label alignment options "Left" and "None".
> Would it make sense to have an additional option "Top"? If so, can you
> add it?
> Greetings
> Matthias
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [ECP] Additional label alignment option "Top"? [message #1691423 is a reply to message #1691219] |
Tue, 07 April 2015 08:16 |
Matthias Juchmes Messages: 22 Registered: March 2015 |
yes, I'm talking about EMF Forms. Thanks for your answer, I created a Bug Report
Greetings
Matthias
Jonas Helming wrote on Fri, 03 April 2015 14:06Hi,
Jonas
> Hello,
> add it?
> Greetings
> Matthias
FUDForum. Page generated in 0.05535 seconds
