Home » Modeling » TMF (Xtext) » got "Cyclic resolution of lazy links" when nested object access parent object
got "Cyclic resolution of lazy links" when nested object access parent object [message #1690924] Tue, 31 March 2015 21:07 Go to next message
I got "Cyclic resolution of lazy links" when nested object access parent object .I try to solve this problem many days.
I have a grammar,like this:
grammar com.huawei.cs.ucl.Ucl with org.eclipse.xtext.common.Terminals
generate ucl "this is a url"
UclProgram:
  (package=PackageDeclaration)?
  (imports+=ImportDeclaration)*
  (classes+=UclClass)*
  (instances+=UclInstance)*
ModuleDeclaration:
  'module' name= QualifiedName id=INT
PackageDeclaration:
  'package' name = [ModuleDeclaration | QualifiedName]
ImportDeclaration:
  'import'  importedNamespace = QualifiedName | importedNamespace= QualifiedNameWithWildcard
QualifiedName:
  ID ('.' ID)*
QualifiedNameWithWildcard:
  QualifiedName ('.*')?
UclClass:
	'class' name=ID
		(members+=UclClassMember)*
UclClassMember:
	UclClassField
UclClassField:
	type=[UclClass] name=ID ('[' minSize=INT ',' maxSize=ArrayUpperLimit ']')? ';'
ArrayUpperLimit:
	INT | '*'
UclInstance:
	clazz=[UclClass] name=ID
		(attributes+=UclInstanceAttribute)*
UclInstanceAttribute:
	iafield=[UclClassField] iavalue=UclInstanceAttributeValue
UclInstanceAttributeValue:
	UclBasicValue | UclObjectValue | UclArrayValue
UclBasicValue:
	':' value=UclValueObject ';'
UclObjectValue:
UclValueObject:
	INT | STRING
UclArrayValue:
		(elements+=UclArrayElement (',' elements+=UclArrayElement)*)?
UclArrayElement:
	INT | STRING |UclObjectValue
I found, if a feature is a cross reference, I will got a exception when I call the cross reference object 's member.
whatever I modify the grammar, I can't avoid this exception.
org.eclipse.xtext.linking.lazy.LazyLinkingResource$CyclicLinkingException: Cyclic resolution of lazy links : UclInstanceAttribute.iafield->UclInstanceAttribute.iafield in resource 'platform:/resource/project3/src/file3.ucl'.
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.handleCyclicResolution(LazyLinkingResource.java:303)
this is my dsl example :
class string{}
class int{}
class javascript{}
class Product
	int prodID;
	string prodName;
	string attributes[0,10];
	Price prices[0,*];
class Price
	int priceID;
	int amount;
class Customer
	int id;
	string name;
	Product offer;
	javascript init;
Customer cust
	offer {
		prodID:23;
		prodName:"prod1";
		prices[
			Price price1{
			Price price2{
public IScope scope_UclInstanceAttribute_iafield(
			UclInstanceAttribute parentAttribute, EReference reference) {
		System.out.println("scope_UclInstanceAttribute_iafield:"
				+ parentAttribute.toString());
		ArrayList<UclClassField> fields = new ArrayList<UclClassField>();
		if (parentAttribute.getIafield()!=null) {
			StringBuffer sb=new StringBuffer();
			sb.append(parentAttribute.getIafield().eCrossReferences().toString());
			System.out.println(sb);
			UclClass clazz = (UclClass) parentAttribute.getIafield().getType();
			EList<UclClassMember> members = clazz.getMembers();
			for (UclClassMember member : members) {
				if (member instanceof UclClassField) {
					UclClassField field = (UclClassField) member;
					fields.add(field);
		return Scopes.scopeFor(fields);
I have to access the class member's type to support content assistant and link.
For example I have to get offer class type and members inside offer instance.
I guess I could use different method to access context and get the class type.
could you help me solve this problem?
thanks!
[Updated on: Tue, 31 March 2015 21:33] by Moderator
Re: got "Cyclic resolution of lazy links" when nested object access parent object [message #1690945 is a reply to message #1690924] Wed, 01 April 2015 04:16 Go to previous messageGo to next message
recursive scoping does not work with xtext. the following example works for me, maybe you can adapt it to your needs
Model:
	entities+=Entity*
	instances+=ClassInstance*;
Entity:
	"entity" name=ID "{"
	fields+=Field*
Field:
	Attribute | Reference;
Attribute:
	"attr" name=ID ":" simpleType=SimpleType;
Reference:
	"ref" name=ID ":" entityType=[Entity];
enum SimpleType:
	string | int | boolean;
ClassInstance:
	name=ID type=[Entity]
	value+=AttributeInstance*
AttributeInstance:
	fieldReference=[Field]
	(expressions+=InstanceExpression
	| '[' expressions+=InstanceExpression (',' expressions+=InstanceExpression)* ']');
InstanceExpression:
	Literal
	| AttributeInstanceExpression;
AttributeInstanceExpression:
	{AttributeInstanceExpression}
	values+=AttributeInstance*
Literal:
	StringLiteral
	| NumberLiteral
	| BooleanLiteral;
StringLiteral:
	value=STRING;
NumberLiteral:
	value=INT;
BooleanLiteral:
	{BoolescherAusdruck} ((value?="true") | "false");
class MyDslScopeProvider extends AbstractDeclarativeScopeProvider {
	def public IScope scope_AttributeInstance_fieldReference(AttributeInstance inst, EReference ref) {
		var EObject container = inst.eContainer();
		if (container instanceof ClassInstance) {
			return scope_AttributeInstance_fieldReference(container as ClassInstance, ref);
		} else if (container instanceof AttributeInstanceExpression) {
			return scope_AttributeInstance_fieldReference(container as AttributeInstanceExpression, ref);
		return IScope.NULLSCOPE;
	def public IScope scope_AttributeInstance_fieldReference(AttributeInstanceExpression expr, EReference ref) {
		val field = (expr.eContainer() as AttributeInstance).fieldReference;
		if (field instanceof Reference) {
			return Scopes.scopeFor(field.entityType.fields)
	def public IScope scope_AttributeInstance_fieldReference(ClassInstance cls, EReference ref) {
		return Scopes.scopeFor(cls.type.fields);
icon8.gif  Re: got "Cyclic resolution of lazy links" when nested object access parent object [message #1691070 is a reply to message #1690945] Thu, 02 April 2015 02:33 Go to previous messageGo to next message
Hi Christian,
Thought this is not a good message, I still thank you very much.
I will give up in this way, and I will use content assistant and validation to do this.
Re: got "Cyclic resolution of lazy links" when nested object access parent object [message #1696873 is a reply to message #1691070] Fri, 29 May 2015 04:01 Go to previous message
Calling 'parentAttribute.getIafield()' will trigger resolution of the attribute you are currently trying to resolve (it is cyclic, and no framework in the world can deal with that).
What you wanted to do is:
parentAttribute = EcoreUtil2.getContainerOfType(parentAttribute, UclInstanceAttribute.class);
// .. your code here...
That could should be more robust of course and you probably also want to rename the parameter name.
Hope that helps,
Sven
[Updated on: Fri, 29 May 2015 04:03] by Moderator
Previous Topic:Autocomplete inside quoted string
Next Topic:why the resource list of resourceset doesnot include all resource?
Current Time: Wed Oct 15 17:49:39 EDT 2025
Powered by FUDForum. Page generated in 0.22361 seconds
