Home » Eclipse Projects » RCP Testing Tool » RCPTT Maven packaging error(I see an error when I do maven build)
RCPTT Maven packaging error [message #1690797] Tue, 31 March 2015 06:46 Go to next message
The following is the error
[INFO] Sys arch is amd64
[INFO] classifier is not specified for AUT, setting to linux.gtk.x86_64 by default
[DEBUG] Could not find metadata /maven-metadata.xml in local (/usr2/c_jrex/.m2/repository)
[DEBUG] Failure to find /maven-metadata.xml in https://repo.maven.apache.org/maven2 was cached in the local repository, resolution will not be reattempted until the update interval of central has elapsed or updates are forced
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 10.060 s
[INFO] Finished at: 2015-03-31T03:17:00-07:00
[INFO] Final Memory: 9M/121M
[ERROR] Failed to execute goal com.xored.ci4rcptt:ci4rcptt-maven-plugin:1.5.4:resources (default-resources) on project productTests: Failed to resolve artifact ::zip:linux.gtk.x86_64:[0.0.1,) -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.xored.ci4rcptt:ci4rcptt-maven-plugin:1.5.4:resources (default-resources) on project productTests: Failed to resolve artifact ::zip:linux.gtk.x86_64:[0.0.1,)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
	at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
	at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
	at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
	at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
	at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
	at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
	at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
	at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
	at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoFailureException: Failed to resolve artifact ::zip:linux.gtk.x86_64:[0.0.1,)
	at com.xored.q7.maven.util.CoordResolver.resolveVersion(CoordResolver.java:196)
	at com.xored.q7.maven.util.CoordResolver.resolveArtifact(CoordResolver.java:97)
	at com.xored.q7.maven.util.CoordResolver.resolve(CoordResolver.java:74)
	at com.xored.q7.maven.PrepareMojo.unpackApps(PrepareMojo.java:114)
	at com.xored.q7.maven.PrepareMojo.execute(PrepareMojo.java:32)
	at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
	... 20 more
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
I have attached the pom.xml , PFA.
I generated the pom.xml from RCPTT application itself.
  • Attachment: pom.xml
    (Size: 8.66KB, Downloaded 295 times)
Re: RCPTT Maven packaging error [message #1690929 is a reply to message #1690797] Tue, 31 March 2015 23:18 Go to previous messageGo to next message
Please fill in
  • configuration/aut/artifactId
  • configuration/aut/groupId
  • configuration/aut/versionId
or configuration/aut/explicit (with a path to AUT installation folder or to a ZIP archive with AUT product).
See reference on http://rcptt.xored.com/maven-plugin
Re: RCPTT Maven packaging error [message #1690985 is a reply to message #1690929] Wed, 01 April 2015 08:37 Go to previous messageGo to next message
Hi Vasili GulevichFriend,
I have filled those now as the following.
<groupId>com.abc</groupId>
<artifactId>com.abc.rcptt.product</artifactId>
<version>1.0.0-SNAPSHOT</version>
yet the error still exists.
Thank you
Jeevan
Re: RCPTT Maven packaging error [message #1690992 is a reply to message #1690985] Wed, 01 April 2015 09:04 Go to previous messageGo to next message
Jeevan Rex wrote on Wed, 01 April 2015 08:37
There is a known issue with this plugin that is fails on artifacts, that were not installed or deployed. Be sure to install com.abc:com.abc.rcptt.product to your Maven repository.
Also, please, quote new error and new pom content.
[Updated on: Wed, 01 April 2015 09:12] by Moderator
Re: RCPTT Maven packaging error [message #1691093 is a reply to message #1690992] Thu, 02 April 2015 05:48 Go to previous messageGo to next message
Is the groupId and artifactId need to be very specific? I can give any string as groupID right?
Re: RCPTT Maven packaging error [message #1691094 is a reply to message #1690992] Thu, 02 April 2015 05:56 Go to previous messageGo to next message
I changed the location of my explicit and tried everything from beginning. Now a new error comes.
[INFO] Building zip: /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_New/target/projectName-productTests-1.5.5-SNAPSHOT-result.zip
[DEBUG] adding directory rcptt/
[DEBUG] adding entry rcptt/stdout.txt
[DEBUG] adding entry rcptt/stderr.txt
[DEBUG] adding entry rcptt/log.txt
[INFO] Total time: 05:26 min
[INFO] Finished at: 2015-04-02T02:41:21-07:00
[INFO] Final Memory: 11M/121M
[ERROR] Failed to execute goal com.xored.ci4rcptt:ci4rcptt-maven-plugin:1.5.4:package (default-package) on project productTests: Could not read test results file /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_New/target/surefire-reports/TEST-productTests.junit.xml -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.xored.ci4rcptt:ci4rcptt-maven-plugin:1.5.4:package (default-package) on project productTests: Could not read test results file /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_New/target/surefire-reports/TEST-productTests.junit.xml
Caused by: org.apache.maven.plugin.MojoFailureException: Could not read test results file /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_New/target/surefire-reports/TEST-productTests.junit.xml
	at com.xored.q7.maven.PackageMojo.readError(PackageMojo.java:109)
	at com.xored.q7.maven.PackageMojo.failBuildIfFailingTests(PackageMojo.java:56)
	at com.xored.q7.maven.PackageMojo.execute(PackageMojo.java:47)
	... 20 more
[ERROR]
[ERROR]
It looks similar, what can I do?
What do you mean by "install com.abc:com.abc.rcptt.product to your Maven repository" - how to do that? please let me know
Thank you
Jeevan
Re: RCPTT Maven packaging error [message #1691333 is a reply to message #1691094] Mon, 06 April 2015 02:43 Go to previous messageGo to next message
The attached log is truncated, could you please attach the whole log file?
As for installing to Maven repository find more details here.
Re: RCPTT Maven packaging error [message #1691342 is a reply to message #1691333] Mon, 06 April 2015 05:22 Go to previous messageGo to next message
Please find attachment below
I think the origin of the error is here:
surefire-reports/TEST-productTests.junit.xml is not generated. Why is that?
It has not produced anything inside surefire-reports directory. See here:
vl-c-jrex-ice{114}> ls
projectName-productTests-1.5.5-SNAPSHOT-result.zip projects/ results/ runner/ runner-workspace/ surefire-reports/
vl-c-jrex-ice{115}> pwd
vl-c-jrex-ice{117}> ls surefire-reports/ -a
vl-c-jrex-ice{118}>
I did mvn package install
A solution is given here: http://stackoverflow.com/questions/9387052/maven-surefire-report-plugin-not-generating-surefire-report-html
but it did not work . Any suggestions?
  • Attachment: log
    (Size: 34.38KB, Downloaded 226 times)
    (Size: 8.86KB, Downloaded 264 times)
[Updated on: Mon, 06 April 2015 07:01] by Moderator
Re: RCPTT Maven packaging error [message #1692794 is a reply to message #1691342] Sat, 18 April 2015 15:13 Go to previous messageGo to next message
Hi!
Could you fix this problem? I have the same issue. Thanks for your answer.
Re: RCPTT Maven packaging error [message #1692834 is a reply to message #1692794] Mon, 20 April 2015 03:00 Go to previous messageGo to next message
I see an error in attached log:
[INFO] Complete OK
[INFO] Verifying licenses...
[INFO]     FM_New... No license. Project skipped.
[INFO] No tests to run.
[INFO] Finished at Mon Apr 06 02:18:44 PDT 2015
[INFO] Runner exit code is: 0
It means that you use proprietary version of runner.
RCPTT Runner recently became Open Source. You can find more information here.
Re: RCPTT Maven packaging error [message #1692868 is a reply to message #1692834] Mon, 20 April 2015 06:20 Go to previous messageGo to next message
Hi!
Thanks for your answer. Now it works for me, if I run "mvc clean package" in terminal. But it doesn't work if I try to run it with Jenkins. It can not find my test files as you can see. Can you help with this problem?
Started by user anonymous
Building in workspace /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://github.com/Bator92/EMF-IncQuery-RCPTT-UI-Tests.git # timeout=10
Fetching upstream changes from https://github.com/Bator92/EMF-IncQuery-RCPTT-UI-Tests.git
> git --version # timeout=10
> git -c core.askpass=true fetch --tags --progress https://github.com/Bator92/EMF-IncQuery-RCPTT-UI-Tests.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse refs/remotes/origin/master^{commit} # timeout=10
> git rev-parse refs/remotes/origin/origin/master^{commit} # timeout=10
Checking out Revision c795a28278a82aeb85b93e72f5221247e08e23c4 (refs/remotes/origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f c795a28278a82aeb85b93e72f5221247e08e23c4
> git rev-list c795a28278a82aeb85b93e72f5221247e08e23c4 # timeout=10
[workspace] $ /var/lib/jenkins/tools/hudson.tasks.Maven_MavenInstallation/mavenHOME/bin/mvn clean package
[INFO] Scanning for projects...
[INFO]
[INFO] Building rcpttTests 1.0.0
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ rcpttTests ---
[INFO] Deleting /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target
[INFO]
[INFO] --- ci4rcptt-maven-plugin:1.5.6-SNAPSHOT:resources (default-resources) @ rcpttTests ---
[INFO] Using AUT from /usr/eclipse-IncQuery-AUT
[INFO] Extracting RCPTT runner to /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/runner
[INFO] Copying project contents to target directory...
[INFO]
[INFO] --- ci4rcptt-maven-plugin:1.5.6-SNAPSHOT:execute (default-execute) @ rcpttTests ---
[INFO] Runner command line is /bin/sh -c cd /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/runner/eclipse && /usr/java/jdk1.8.0_40/jre/bin/java -Xms128m -Xmx256m -Dcom.xored.q7.runner.returnTestFailure=true -jar /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/runner/eclipse/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar -application org.eclipse.rcptt.runner.headless -data /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/runner-workspace -aut /usr/eclipse-IncQuery-AUT -autWsPrefix /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/aut-ws- -autConsolePrefix /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/results/aut-console- -q7report /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/results/rcpttTests.report -htmlReport /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/results/rcpttTests.html -junitReport /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/surefire-reports/TEST-rcpttTests.xml -import /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/projects/rcpttTests -testOptions 'testExecTimeout=300;execTimeout=3600' -shutdownListenerPort 8748
[INFO] The execution timeout is set to 3600 seconds
[INFO] Started at Mon Apr 20 11:43:06 CEST 2015
[INFO] RCPTT Runner version: 1.5.6
[INFO] Initializing target platform...
[INFO] Target platform is valid.
[INFO] Looking for tests...
[INFO] Existing projects in workspace:
[INFO] <none>
[INFO] No projects to import
[INFO] No projects ready to test
[INFO] Finished at Mon Apr 20 11:43:27 CEST 2015
[INFO]
[INFO] --- ci4rcptt-maven-plugin:1.5.6-SNAPSHOT:package (default-package) @ rcpttTests ---
[INFO] Building zip: /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/projects/rcpttTests-1.0.0.zip
[INFO] Building zip: /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/IncQueryProject-rcpttTests-1.0.0-result.zip
[INFO] Total time: 32.887 s
[INFO] Finished at: 2015-04-20T11:43:29+02:00
[INFO] Final Memory: 9M/217M
[ERROR] Failed to execute goal com.xored.ci4rcptt:ci4rcptt-maven-plugin:1.5.6-SNAPSHOT:package (default-package) on project rcpttTests: Could not read test results file /var/lib/jenkins/jobs/EMF-IncQuery_RCPTT_UI_Tests/workspace/target/surefire-reports/TEST-rcpttTests.junit.xml -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
Build step 'Invoke top-level Maven targets' marked build as failure
Finished: FAILURE
[Updated on: Mon, 20 April 2015 06:20] by Moderator
Re: RCPTT Maven packaging error [message #1692873 is a reply to message #1692868] Mon, 20 April 2015 07:13 Go to previous messageGo to next message
Hi András Bátor,
What did you change to make it work. My application doesn't have any Licencing. There is one which I have set in my rc file which get sets automatically during boot.
Please let me know the changes you made.
Thank you
Jeevan
Re: RCPTT Maven packaging error [message #1692875 is a reply to message #1692873] Mon, 20 April 2015 07:21 Go to previous messageGo to next message
Hi!
I have started using the nightly version of the runner. So, I downloaded the .zip file. My pom.xml looks like this now. But it doesn't works for me with Jenkins.:
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
  <modelVersion>4.0.0</modelVersion>
  <!-- Change groupId, artifactId and version -->
  <artifactId>rcpttTests</artifactId>
  <groupId>IncQueryProject</groupId>
  <version>1.0.0</version>
  <packaging>rcpttTest</packaging>
  <!-- Change properies below to your values -->
  <properties>
    	<autPath>/home/97204/Development/eclipse-IncQuery-AUT</autPath>
  </properties>
  <build>
    <plugins>
      <plugin>
        <groupId>com.xored.ci4rcptt</groupId>
        <artifactId>ci4rcptt-maven-plugin</artifactId>
        <version>1.5.6-SNAPSHOT</version>
        <extensions>true</extensions>
        <configuration>
          <aut>
            <explicit>${autPath}</explicit>
          </aut>
          <runner>
            <explicit>/home/97204/Downloads/rcptt.runner-incubation-1.5.6-N201504182315.zip</explicit>
          </runner>
        </configuration>
      </plugin>
    </plugins>
  </build>
  <pluginRepositories>
    <pluginRepository>
      <id>xored-releases</id>
      <name>Xored Maven repository</name>
      <url>http://maven.xored.com/nexus/content/repositories/ci4rcptt-snapshots/</url>
    </pluginRepository>
  </pluginRepositories>
</project>
[Updated on: Mon, 20 April 2015 07:24] by Moderator
Re: RCPTT Maven packaging error [message #1692876 is a reply to message #1692875] Mon, 20 April 2015 07:34 Go to previous messageGo to next message
I think your Jenkins server needs either XVNC or gtk installed. Check if those are there in Jenkins server.
Re: RCPTT Maven packaging error [message #1692880 is a reply to message #1692876] Mon, 20 April 2015 07:54 Go to previous messageGo to next message
Here are the details of how to configure Jenkins job.
Did you do the same steps?
Re: RCPTT Maven packaging error [message #1692882 is a reply to message #1692880] Mon, 20 April 2015 08:28 Go to previous messageGo to next message
I have changed my pom.xml similar to your pom file. But still some issue is there. I have attached my pom.xml and also the output of mvn clean package -X (log.txt)
Let me know how could this be solved. Please find attachment.
Thank you
  • Attachment: log.txt
    (Size: 21.19KB, Downloaded 306 times)
    (Size: 1.22KB, Downloaded 239 times)
Re: RCPTT Maven packaging error [message #1693024 is a reply to message #1692882] Tue, 21 April 2015 06:03 Go to previous messageGo to next message
Hi!
It's interesting. Your pom looks like very similar to mine. I don't know what could be the problem. Sad
But I have problem with running on Jenkins.
http://support.xored.com/support/solutions/articles/3000028645-use-jenkins-to-run-rcptt-tests-in-continuos-integration-environment-
I made these steps, except that I use my pom.xml (mentioned above). And I am using it with my github repo:
https://github.com/Bator92/EMF-IncQuery-RCPTT-GUI-Tests
But all of my tests failed with the first ECL Command (eg. Failed to set selection: [....]). According to the output rcpttTests.html, the workspace was created. The tests are working running it from it's folder with the "mvn clean package" command. What can be the problem?
Re: RCPTT Maven packaging error [message #1693052 is a reply to message #1693024] Tue, 21 April 2015 08:39 Go to previous messageGo to next message
Try to add Workbench context, probably needed perspective or view isn't opened.
Could you please attach HTML-report?
Re: RCPTT Maven packaging error [message #1693072 is a reply to message #1693052] Tue, 21 April 2015 10:14 Go to previous messageGo to next message
Hi!
I have attached my target folder's most important directories. Theoritically, the workbench and workspace context were created, but unfortunately I cannot se on the screenshots. What do you think? What can be the problem?
  • Attachment: target.zip
    (Size: 3.29MB, Downloaded 232 times)
Re: RCPTT Maven packaging error [message #1693169 is a reply to message #1693072] Wed, 22 April 2015 04:40 Go to previous messageGo to next message
Hi András Bátor,
Which version of Maven are you using? I am using 3.3.1.
Jeevan
Re: RCPTT Maven packaging error [message #1693181 is a reply to message #1693169] Wed, 22 April 2015 05:55 Go to previous messageGo to next message
Hi!
I am using 3.3.1 too.
Re: RCPTT Maven packaging error [message #1693185 is a reply to message #1693181] Wed, 22 April 2015 06:02 Go to previous messageGo to next message
I think the issue starts here:
[DEBUG] expand complete
[INFO]
[INFO] --- ci4rcptt-maven-plugin:1.5.6-SNAPSHOT:execute (default-execute) @ productTests ---
[DEBUG] Configuring mojo com.xored.ci4rcptt:ci4rcptt-maven-plugin:1.5.6-SNAPSHOT:execute from plugin realm ClassRealm[extension>com.xored.ci4rcptt:ci4rcptt-maven-plugin:1.5.6-SNAPSHOT, parent: sun.misc.Launcher$AppClassLoader@5306989e]
[DEBUG] Configuring mojo 'com.xored.ci4rcptt:ci4rcptt-maven-plugin:1.5.6-SNAPSHOT:execute' with basic configurator -->
[DEBUG]   (s) explicit = /prj/iceng/qsip1/workspaces/fusemaster/linux-qsip2.1.2forJeevan/linux/
[DEBUG]   (f) aut = Coords [artifactId=null, groupId=null, version=null]
[DEBUG]   (f) outDir = /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target
[DEBUG]   (f) project = MavenProject: projectName:productTests:1.5.5-SNAPSHOT @ /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/pom.xml
[DEBUG]   (f) repoSession = org.eclipse.aether.DefaultRepositorySystemSession@10cbf9d9
[DEBUG]   (s) version = 1.5.6-SNAPSHOT
[DEBUG]   (f) runner = Coords [artifactId=null, groupId=null, version=1.5.6-SNAPSHOT]
[DEBUG]   (f) skipTests = false
[DEBUG]   (f) testFailureIgnore = false
[DEBUG] -- end configuration --
[INFO] Runner command line is /bin/sh -c cd /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target/runner/eclipse && dfdfm -Dcom.xored.q7.runner.returnTestFailure=true -XX:MaxPermSize=256m -jar /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target/runner/eclipse/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar -application org.eclipse.rcptt.runner.headless -data /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target/runner-workspace -aut /prj/iceng/qsip1/workspaces/fusemaster/linux-qsip2.1.2forJeevan/linux -autWsPrefix /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target/aut-ws- -autConsolePrefix /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target/results/aut-console- -q7report /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target/results/productTests.report -htmlReport /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target/results/productTests.html -junitReport /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target/surefire-reports/TEST-productTests.xml -import /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target/projects/productTests -testOptions 'execTimeout=3600;testExecTimeout=300' -shutdownListenerPort 9481
[INFO] An error has occurred. See the log file
[INFO] /prj/iceng/qsip1/workspaces/c_jrex/RCPTT/workspace_rcptt/FM_Jenkins_TestRunner/target/runner/eclipse/configuration/1429784143465.log.
[INFO] Runner exit code is: 13
[INFO] Total time: 20.130 s
[INFO] Finished at: 2015-04-23T03:15:53-07:00
[INFO] Final Memory: 10M/121M
[ERROR] Failed to execute goal com.xored.ci4rcptt:ci4rcptt-maven-plugin:1.5.6-SNAPSHOT:execute (default-execute) on project productTests: Failed to launch RCPTT runner: Runner exit code is: 13 -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.xored.ci4rcptt:ci4rcptt-maven-plugin:1.5.6-SNAPSHOT:execute (default-execute) on project productTests: Failed to launch RCPTT runner
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:216)
Caused by: org.apache.maven.plugin.MojoExecutionException: Failed to launch RCPTT runner
	at com.xored.q7.maven.ExecuteMojo.execute(ExecuteMojo.java:268)df
	... 20 more
Caused by: org.apache.maven.plugin.MojoFailureException: Runner exit code is: 13
	at com.xored.q7.maven.ExecuteMojo.execute(ExecuteMojo.java:260)
	... 22 more
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
java.net.ConnectException: Connection refused
[INFO] Process terminated. Send shutdown request to RCPTT runner.
The packaging type "rcpttTest" is a predefined one right? Or is it related to my project? Do I need to include any RCPTT free licence file?
  • Attachment: Current.txt
    (Size: 29.43KB, Downloaded 290 times)
[Updated on: Thu, 23 April 2015 07:32] by Moderator
Re: RCPTT Maven packaging error [message #1693341 is a reply to message #1693169] Thu, 23 April 2015 07:57 Go to previous messageGo to next message
It's interesting. I see in HTML-report, that workspace is applied.
In shared report in swt.info I see the following snippet:
view:Project Explorer {
id=org.eclipse.ui.navigator.ProjectExplorer
dirty=false
fastView=false
View(Project Explorer) {
Toolbar() {
Button(Collapse All (M1+M2+Numpad_Divide)) Button(Link with Editor) Button(Focus on Active Task (Alt+click to reveal filtered elements)) }
Tree() {
Item(> school.incquery [workspace origin/master 6fba308]) Item(> school.incquery.validation [workspace origin/master 6fba308]) Item(> school.instancemodel [workspace origin/master 6fba308]) }
And if I try to reproduce it locally with your test project swt.info contains
dirty=false
fastView=false
Toolbar() {
Tree() {
Item(school.incquery) Item(school.instancemodel) {
Item(META-INF) Item(build.properties) Item(BUTE.school) Item(Hogwarts.school) Item(pom.xml) }
In your info there is Item(> school.instancemodel [workspace origin/master 6fba308]) instead of Item(school.instancemodel).
That's why tests fail. Do you have an idea why it happens?
As a workaround you can use regular expressions:
select ".*school.instancemodel.*/BUTE.school"
Re: RCPTT Maven packaging error [message #1693585 is a reply to message #1693341] Sat, 25 April 2015 15:22 Go to previous messageGo to next message
Now I have tried everything in a new environment in my personnel laptop. My AUT is nothing but the latest download of eclipse. I created a test case and did maven run. Was able to run, then will there be an issue with the earlier AUT? How can I find that?
Thank you.
Jeevan
[Updated on: Sun, 26 April 2015 06:58] by Moderator
Re: RCPTT Maven packaging error [message #1693773 is a reply to message #1693585] Tue, 28 April 2015 06:04 Go to previous message
Thank you guys,
I am able to run it now. But issue when running with Jenkins. I have attached the Jenkins log here.
Please let me know the solution for Jenkins
I am almost using the same setup here http://support.xored.com/support/solutions/articles/3000028645-use-jenkins-to-run-rcptt-tests-in-continuos-integration-environment- But I am trying to run from my local and not in Git. It is from my local directory.
  • Attachment: Jenkins.txt
    (Size: 14.12KB, Downloaded 316 times)
Previous Topic:Need help on ECL script
Next Topic:ECL: String Concatenation
Current Time: Tue Oct 28 18:02:57 EDT 2025
Powered by FUDForum. Page generated in 0.31968 seconds
