IllegalArgumentException: Can only deactivate the active transaction [message #1690468] |
Fri, 27 March 2015 12:59 |
Sebastian Lehrig Messages: 16 Registered: July 2012 |
when I try to alter my model using the Sirius tooling, an "IllegalArgumentException: Can only deactivate the active transaction" is thrown (detailed stack trace & environment details below). For example, this happens if I try to add a new class to my domain model. The change is neither shown in the editor nor serialized to the ecore file.
Any ideas on this issue?
Sebastian
My Project:
Source here
I just converted my non-modelling project (already including a *.aird file) into a modelling project. My *.aird file is within a "model" subfolder that also includes my domain model. My domain model also references several other models from external plugins.
Environment:
OS X Yosemite, Version 10.10.2
Eclipse Modeling Tools
Version: Luna Service Release 2 (4.4.2)
Build id: 20150219-0600
Sirius 1.0.2.201501270932
java version "1.8.0_25"
Java(TM) SE Runtime Environment (build 1.8.0_25-b17)
Java HotSpot(TM) 64-Bit Server VM (build 25.25-b02, mixed mode)
Session Data:
eclipse.buildId=4.4.2.M20150204-1700
java.version=1.8.0_25
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.modeling.product -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.modeling.product
Stacktrace:
org.eclipse.core.commands.ExecutionException: While executing the operation, an exception occurred
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:521)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:75)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:57)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:156)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTool.java:425)
at org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(AbstractTool.java:438)
at org.eclipse.gef.tools.CreationTool.performCreation(CreationTool.java:269)
at org.eclipse.gef.tools.CreationTool.handleButtonUp(CreationTool.java:189)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java:1200)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:301)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouseReleased(DomainEventDispatcher.java:380)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(LightweightSystem.java:548)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:220)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4199)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1467)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1490)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1475)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4042)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3669)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.IllegalArgumentException: Can only deactivate the active transaction
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.deactivate(TransactionalEditingDomainImpl.java:533)
at org.eclipse.emf.transaction.impl.TransactionImpl.close(TransactionImpl.java:712)
at org.eclipse.emf.transaction.impl.TransactionImpl.commit(TransactionImpl.java:474)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:155)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:134)
at org.eclipse.sirius.diagram.ui.tools.internal.commands.WrappingCommandIgnoringAffectedFiles.execute(WrappingCommandIgnoringAffectedFiles.java:124)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
... 41 more
[Updated on: Fri, 27 March 2015 13:17] Report message to a moderator
Re: IllegalArgumentException: Can only deactivate the active transaction [message #1690702 is a reply to message #1690468] |
Mon, 30 March 2015 16:46 |
Are you modifying the semantic model using a tool provided by Sirius,
like a node creation tool? or is it through some custom code?
If it is with custom code, are you executing it as a RecordingCommand in
the context of the transactional editing domain of the Sirius session?
Steve
Le 27/03/2015 13:59, Sebastian Lehrig a écrit :
> Hello,
> Thanks
> Sebastian
> My Project:
> Environment:
> Session Data:
> java.vendor=Oracle Corporation
> -keyring /Users/lehrig/.eclipse_keyring -showlocation
> Stacktrace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> active transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 41 more
Steve Monnier - Obeo
Need professional services for Sirius?
Steve Monnier - Obeo Canada
FUDForum. Page generated in 0.02829 seconds
