Home » Modeling » Epsilon » Custom properties in eugenia generated editor.
Custom properties in eugenia generated editor. [message #1690340] Thu, 26 March 2015 12:29 Go to next message
Hello there,
I would like to create a custom properties sheet. Based on the material that I read, the changes are applied to the .gmfgen file. However, EuGeNia is responsible for the generation of the editor at once.
I have applied multiple adjustments to the ECoreToGMF.eol generally so I kind of know the process.
Now my question is will I have to use the FixGMFGen.eol in order to achieve something like this? Are there any samples available on how to retrieve children, attribute and set properties for the fixGMFgen?
Best Regards, Nikos
[Updated on: Thu, 26 March 2015 12:31] by Moderator
Re: Custom properties in eugenia generated editor. [message #1690346 is a reply to message #1690340] Thu, 26 March 2015 13:28 Go to previous messageGo to next message
Hi Niko,
If you need to modify the .gmfgen model, FixGMFGen.eol is the right place to be looking at. I'm not aware of any examples of customising the editor's property sheet but googling for "FixGMFGen.eol" returned the following which may help:
https://github.com/bluezio/eugenia-epsilon-example/blob/master/dsdm.eugenia/FixGMFGen.eol
https://code.google.com/p/metagem/source/browse/trunk/mm_Hybrid/model/FixGMFGen.eol?r=519
Dimitris
Re: Custom properties in eugenia generated editor. [message #1690357 is a reply to message #1690346] Thu, 26 March 2015 16:01 Go to previous messageGo to next message
Thank you Dimitris, I will look into it.
Btw thank you for the overall try to keep the forum running and have all the questions answered.
I am sure a lot of people appreciate that, as it does not happen very often in Eclipse forums.
Best
[Updated on: Thu, 26 March 2015 16:02] by Moderator
Re: Custom properties in eugenia generated editor. [message #1690365 is a reply to message #1690357] Thu, 26 March 2015 18:08 Go to previous message
Hi Niko,
Thanks for the positive feedback - it's really appreciated.
Dimitris
Previous Topic:[Epsilon] Epsilon does not find a type
Next Topic:EVL - Getting the name of the file in which the model is stored
Current Time: Fri Nov 07 08:02:37 EST 2025
Powered by FUDForum. Page generated in 0.03599 seconds
