Re: The configured runtime is insufficient to provide an implementation for JAXB 2.2 [message #1690330 is a reply to message #1690322] |
Thu, 26 March 2015 16:05 |
David Goodenough Messages: 157 Registered: July 2009 |
Neil Hauge wrote on Thu, 26 March 2015 11:16There must be a bug in the way Dali is interrogating the Java 8 runtime for JAXB 2.2 compliance. I would file a bug against Dali for this so it can be fixed in the upcoming Mars release, and possibly be put into a Luna maintenance release.
For now, you should be able to workaround the issue by disabling library configuration, which really just turns off this validation. It assumes your library is correct based on your specific configuration, and everything should work fine, assuming it is.
Neil
Looking in the Bug tracker, this looks like https://bugs.eclipse.org/bugs/show_bug.cgi?id=437635 but that says it is already there - or am I misreading it?
The problem is that it generates an error saying that "the currently selected JAX-B library provider is invalid", and it will not let me enable the JAX-B Facet.
If this version hasnot been released yet, is there a way to download a development version and load that? If not when is this due to hit the streets?
David
FUDForum. Page generated in 0.04705 seconds
