How to cancel job: Auto-sharing imported subversion projects [message #1689799] |
Tue, 24 March 2015 07:00  |
I am generating a bunch of projects in eclipse based on svn sources when projects are too many, they are closed after generation.
But I am getting a log of stack trace error messages from the job:
org.tigris.subversion.subclipse.core.SVNTeamProviderType
inner job AutoShareJob (Auto-sharing imported subversion projects)
!ENTRY org.tigris.subversion.subclipse.core 4 0 2015-03-24 10:58:38.614
!MESSAGE Could not auto-share project MyProject
!STACK 1
org.eclipse.team.core.TeamException: Resource '/MyProject' is not open.
at org.eclipse.team.internal.core.TeamPlugin.wrapException(TeamPlugin.java:128)
at org.eclipse.team.core.RepositoryProvider.map(RepositoryProvider.java:144)
at org.tigris.subversion.subclipse.core.resources.SVNWorkspaceRoot.setSharing(SVNWorkspaceRoot.java:227)
at org.tigris.subversion.subclipse.core.SVNTeamProviderType$AutoShareJob.autoconnectSVNProject(SVNTeamProviderType.java:138)
at org.tigris.subversion.subclipse.core.SVNTeamProviderType$AutoShareJob.run(SVNTeamProviderType.java:105)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.core.internal.resources.ResourceException: Resource '/ExternalComm' is not open.
at org.eclipse.core.internal.resources.Project.checkAccessible(Project.java:150)
at org.eclipse.core.internal.resources.Resource.checkAccessibleAndLocal(Resource.java:221)
at org.eclipse.core.internal.resources.Resource.getPersistentProperty(Resource.java:1204)
at org.eclipse.team.core.RepositoryProvider.map(RepositoryProvider.java:99)
... 4 more
I do not need from SVn plugins to trigger auto-cennect to project when it is closed.
I see that it should skip running job when project is not accessible (closed) , but for some reason this does not happen.
Where I could get sources for subversion plugins? It seems that I have to investigate deeper , and debug this plugins in order to to find out what really happens.
Is there a simple mechanism that just turns off this features in some cases?
Thank you
Lidia
Re: How to cancel job: Auto-sharing imported subversion projects [message #1728842 is a reply to message #1690593] |
Thu, 07 April 2016 15:13   |
Hello Alexander,
Thank you for your old reply.
I would have a similar question.
Having a simple workspace,
~/dev/workspace/PROJECT1
~/dev/workspace/PROJECT2
The PROJECT1 has an .svn folder, but PROJECT2 does not have it.
In eclipse, one project is created based on sources from PROJECT1, and a new project is created called PROJECT2.
Svn plugin tries to autoshare the project PROJECT2, and it fails , suppose, because it does not have .svn
I would need to avoid having the stacktrace error from svn when it tries to share this project. But I still need the PROJECT1 to be shared.
ENTRY org.tigris.subversion.subclipse.core 4 0 2016-04-07 20:56:25.946
!MESSAGE Could not auto-share project FOLDER2
!STACK 1
org.tigris.subversion.subclipse.core.SVNException: Provided SVN information does not match that on disk for project 'PROJECT2'.
at org.tigris.subversion.subclipse.core.resources.SVNWorkspaceRoot.setSharing(SVNWorkspaceRoot.java:206)
at org.tigris.subversion.subclipse.core.SVNTeamProviderType$AutoShareJob.autoconnectSVNProject(SVNTeamProviderType.java:140)
at org.tigris.subversion.subclipse.core.SVNTeamProviderType$AutoShareJob.run(SVNTeamProviderType.java:106)
!SUBENTRY 1 org.tigris.subversion.subclipse.core 4 4 2016-04-07 20:56:25.947
!MESSAGE Provided SVN information does not match that on disk for project 'PROJECT2 '.
Is it possible using svn api, to notify somehow the SVNWorkspaceRoot to skip sharing a project based on its name?
Thank you in advance
Lidia
[Updated on: Thu, 07 April 2016 15:14] by Moderator
FUDForum. Page generated in 0.03556 seconds
