Solaris 8 or solaris 10 ? [message #325224] |
Tue, 12 February 2008 11:40  |
Dear all,
I'm trying to figure out on which version of Solaris Eclipse is supposed
to be officially running. The eclipse download site says Solaris 8 for
3.3, but on the release notes of the package, only Solaris 10 is
mentioned. Is there a reason for the difference ?
Quentin
Re: Solaris 8 or solaris 10 ? [message #325265 is a reply to message #325246] |
Wed, 13 February 2008 09:45   |
Solaris 10 is the reference platform, meaning it's the one that is tested
and supported. It's also the easiest case from the user's perspective
because this is the first version of solaris that shipped with gtk.
Eclipse should also work on Solaris 8 and 9, but note:
- these require the client to install the gtk packages (2.2.x or newer)
and their dependencies
- these are not tested as part of the regular test cycle
Also note the following, which will enable you to use motif instead of gtk
on Solaris 8 or 9, and therefore don't require any additional package
installation:
- the RCP SDK and SWT Binary are still regularly built for solaris-motif,
so if you just have an RCP app or SWT app that you wish to deploy on a
Solaris 8 or 9 then these should work for you
- if you really want to use eclipse and don't mind using an older
version, the last release that is available for solaris-motif is 3.1.2,
which is available from
http://archive.eclipse.org/eclipse/downloads/drops/R-3.1.2-2 00601181600/index.php
Grant
"Quentin Ochem" <ochem@adacore.com> wrote in message
news:47B2B4EB.40701@adacore.com...
> >> supposed to be officially running. The eclipse download site says
> >> Solaris 8 for 3.3, but on the release notes of the package, only
> >> Solaris 10 is mentioned. Is there a reason for the difference ?
> > Not sure, but if I look at the plan, I notice that Solaris 10 is
mentioned.
> > http://www.eclipse.org/eclipse/development/eclipse_project_p lan_3_3.html
> > Sun Solaris 10, SPARC, GTK running:
> > * Sun Java 2 Standard Edition 5.0 Update 11 for Solaris SPARC
> Thanks for the info - so is the mention of Solaris 8 on the download
> site some kind of outdated information ? Solaris 8 was part of the
> release notes for earlier versions, e.g. 3.1...
Re: Solaris 8 or solaris 10 ? [message #325308 is a reply to message #325265] |
Thu, 14 February 2008 04:37  |
> installation:
> Grant
That's very useful information - thanks a lot for the input!
FUDForum. Page generated in 0.04591 seconds
