Home » Eclipse Projects » Eclipse Platform » Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem)
Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem) [message #325132] Sun, 10 February 2008 07:31 Go to next message
Originally posted by: eclipsenews-9999-exp.sblk.de
I've been using Apache Commons Logging for all my Eclipse plug-ins so
far and didn't run into any problems. However, I've recently installed
the "Jigloo SWT/Swing GUI Builder" plug-in
(http://www.cloudgarden.com/jigloo/) and I am getting lots of class
loading errors now.
I assume that the Jigloo plug-in is using Apache Commons Logging too and
that there is some kind of conflict. But I have no idea where to look
at, at the moment.
Did anyone else run into such problems before?
Example errors, full versions can be found at the end of this post.
a) One type of error which clearly hints at commons logging:
org.eclipse.core.runtime.CoreException: Plug-in
"org.electrocodeogram.cpc.track" was unable to instantiate class
" org.electrocodeogram.cpc.track.listener.CutCopyPasteListener ".
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
org.eclipse.core.runtime.CoreException[1]:
java.lang.ExceptionInInitializerError
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
Caused by: org.apache.commons.logging.LogConfigurationException: The
chosen LogFactory implementation does not extend LogFactory. Please
check your configuration. (Caused by java.lang.ClassNotFoundException:
org.electrocodeogram.cpc.ui.utils.CommonsLogFactoryImpl)
org.apache.commons.logging.LogFactory.createFactory(LogFacto ry.java:1200)
Caused by: java.lang.ClassNotFoundException:
at java.lang.ClassLoader.findClass(ClassLoader.java:358)
The strange thing here is that it shouldn't be trying to load
but
org.electrocodeogram.cpc.track.utils.CommonsLogFactoryImpl
which is configured in a
commons-logging.properties
file in the source directory of the org.electrocodeogram.cpc.track plug-in:
commons-logging.properties contents:
> priority=1
org.apache.commons.logging.LogFactory=org.electrocodeogram.c pc.track.utils.CommonsLogFactoryImpl
b) another type of error which does no longer directly mention commons
logging (but which I assume to be a commons logging issue anyway)
"org.electrocodeogram.cpc.track.listener.PersistenceListener ".
java.lang.NoClassDefFoundError: Could not initialize class
at sun.reflect.GeneratedConstructorAccessor21.newInstance(Unkno wn Source)
Greetings
Hans Meyer
!ENTRY org.electrocodeogram.eclipse.core 4 40000 2008-02-08 18:23:08.000
!MESSAGE ERROR main
org.electrocodeogram.cpc.core.registry.EventHubListenerDescr iptor -
getListener() - unable to instantiate listener class:
org.electrocodeogram.cpc.track.listener.CutCopyPasteListener -
!STACK 1
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:174)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.electrocodeogram.cpc.core.registry.EventHubListenerDescr iptor.getListener(EventHubListenerDescriptor.java:64)
org.electrocodeogram.cpc.core.registry.DefaultEventHubRegist ry.collectInterestedListeners(DefaultEventHubRegistry.java:3 46)
org.electrocodeogram.cpc.core.registry.DefaultEventHubRegist ry.dispatchListeners(DefaultEventHubRegistry.java:223)
org.electrocodeogram.cpc.core.registry.DefaultEventHubRegist ry.dispatch(DefaultEventHubRegistry.java:99)
org.electrocodeogram.cpc.sensor.listener.CPCTextOperationAct ion.run(CPCTextOperationAction.java:178)
at com.cloudgarden.jigloo.editors.FormEditor.doAction(FormEdito r.java:659)
at com.cloudgarden.jigloo.editors.FormEditor$56.run(FormEditor. java:7188)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler. java:185)
org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execut e(LegacyHandlerWrapper.java:109)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:475)
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:429)
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:165)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:470)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:821)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:879)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:568)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:510)
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:126)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:142 3)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1100)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1125)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1110)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1137 )
at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.ja va:663)
at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control. java:2533)
org.eclipse.swt.widgets.Composite.gtk_key_press_event(Compos ite.java:679)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1486)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4234 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3973 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:55 93)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1192)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1487)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2969)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:5 13)
at java.lang.Class.newInstance0(Class.java:355)
at java.lang.Class.newInstance(Class.java:308)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
at org.apache.commons.logging.LogFactory$2.run(LogFactory.java: 994)
at org.apache.commons.logging.LogFactory.newFactory(LogFactory. java:991)
at org.apache.commons.logging.LogFactory.getFactory(LogFactory. java:572)
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java :645)
org.electrocodeogram.cpc.track.listener.CutCopyPasteListener . <clinit>(CutCopyPasteListener.java:40)
... 67 more
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
org.apache.commons.logging.LogFactory.createFactory(LogFacto ry.java:1190)
... 73 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2008-02-08 18:23:08.030
!MESSAGE Plug-in "org.electrocodeogram.cpc.track" was unable to
instantiate class
!STACK 0
... 67 more
... 73 more
org.electrocodeogram.cpc.sensor.listener.CPCFileBufferListen er.dirtyStateChanged(CPCFileBufferListener.java:442)
org.eclipse.core.internal.filebuffers.TextFileBufferManager$ 3.run(TextFileBufferManager.java:640)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.filebuffers.TextFileBufferManager. fireDirtyStateChanged(TextFileBufferManager.java:638)
org.eclipse.core.internal.filebuffers.ResourceFileBuffer.com mit(ResourceFileBuffer.java:335)
org.eclipse.jdt.internal.ui.javaeditor.DocumentAdapter.save( DocumentAdapter.java:424)
org.eclipse.jdt.internal.core.CommitWorkingCopyOperation.exe cuteOperation(CommitWorkingCopyOperation.java:123)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:720)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:785)
org.eclipse.jdt.internal.core.CompilationUnit.commitWorkingC opy(CompilationUnit.java:354)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider.commitWorkingCopy(CompilationUnitDocumentProvider .java:1302)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider$5.execute(CompilationUnitDocumentProvider.java:13 67)
org.eclipse.ui.editors.text.TextFileDocumentProvider$Documen tProviderOperation.run(TextFileDocumentProvider.java:129)
org.eclipse.ui.actions.WorkspaceModifyDelegatingOperation.ex ecute(WorkspaceModifyDelegatingOperation.java:68)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
org.eclipse.ui.internal.editors.text.WorkspaceOperationRunne r.run(WorkspaceOperationRunner.java:73)
org.eclipse.ui.internal.editors.text.WorkspaceOperationRunne r.run(WorkspaceOperationRunner.java:63)
org.eclipse.ui.editors.text.TextFileDocumentProvider.execute Operation(TextFileDocumentProvider.java:450)
org.eclipse.ui.editors.text.TextFileDocumentProvider.saveDoc ument(TextFileDocumentProvider.java:761)
org.eclipse.ui.texteditor.AbstractTextEditor.performSave(Abs tractTextEditor.java:4716)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .performSave(CompilationUnitEditor.java:1216)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .doSave(CompilationUnitEditor.java:1269)
com.cloudgarden.jigloo.editors.FormEditor.updateWorkingCopyI nternal(FormEditor.java:10003)
com.cloudgarden.jigloo.editors.FormEditor.updateWorkingCopy( FormEditor.java:9892)
at com.cloudgarden.jigloo.editors.FormEditor.doSave(FormEditor. java:9657)
org.eclipse.ui.texteditor.AbstractTextEditor$TextEditorSavab le.doSave(AbstractTextEditor.java:6779)
at org.eclipse.ui.Saveable.doSave(Saveable.java:212)
org.eclipse.ui.internal.SaveableHelper.doSaveModel(SaveableH elper.java:339)
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper. java:185)
at org.eclipse.ui.internal.SaveableHelper$4.run(SaveableHelper. java:266)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2451)
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:274)
org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:253)
org.eclipse.ui.internal.SaveableHelper.saveModels(SaveableHe lper.java:196)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:136)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1345)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:3202)
org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:3215)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:73)
at org.eclipse.jface.commands.ActionHandler.execute(ActionHandl er.java:119)
Re: Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem) [message #325135 is a reply to message #325132] Sun, 10 February 2008 09:30 Go to previous messageGo to next message
I think that somewhere you have 2 different instances of commons logging
in your plugins. How to you provide this JAR file? The generally
recommended way to provide an external JAR file like this is wrap it in
it's own plugin.
You might want to look into eclipse orbit, which actually provides a
plugin for commons logging.
Once you fix this problem, your second probably will likely go away.
HTH
Francis
H. Meyer wrote:
> loading errors now.
> at, at the moment.
> at
> at
> but
>> priority=1
> at
> Greetings
> Hans Meyer
> !MESSAGE ERROR main
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 67 more
> at
> at
> at
> at
> at
> ... 73 more
> instantiate class
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 67 more
> at
> at
> at
> at
> at
> ... 73 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem) [message #325138 is a reply to message #325135] Sun, 10 February 2008 12:07 Go to previous messageGo to next message
Hi Francis,
thanks for the pointer.
As I am using Apache Commons Logging 1.1 it is quite possible that the
Jigloo plug-in uses an older version of the library.
However, how can I solve this problem without modifying the Jigloo
plug-in? All my own plug-ins use the same version of the library.
I don't quite get why different versions would cause a problem though.
Shouldn't plug-ins be pretty much separated due to their plug-in class
loaders? Especially because the logger objects are only used locally
within each plug-in.
Another, maybe related matter, is the location of the library. Due to
some class path issues I currently include the Apache Commons Logging
library (~50kB) in all my plug-ins instead of using one shared copy.
The problem here was that I am providing a custom LogFactory
implementation for each plug-in which redirects all log output to the
correct logger (I am using Log4J). These custom factories are specified
via a commons-logging.properties file. In this setup I always ended up
getting class not found exceptions when the Commons Logging library was
not located within the plug-in itself.
Greetings
Hans
> it's own plugin.
> HTH
> Francis
Re: Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem) [message #325139 is a reply to message #325138] Sun, 10 February 2008 12:30 Go to previous messageGo to next message
The fact that you include the library in multiple places is the problem.
The commons logging library checks to see that the LogFactory class is
what it expects, and you are getting the error because of you have two
different instances of the LogFactory class (which is because you define
it in multiple plugins). The fact that these are separated because of
the different class loaders is the source of the problem.
I don't think the addition of the Jigloo stuff has anything to do with
your problem; you are bound to hit this problem based on the way you use
the commons logging library.
I suggest you make a new and separate plugin which has your customized
version of the commons logging library and remove it from all of your
other plugins; this way you will make sure there is only one
implementation and that should make this problem go away.
Francis
H. Meyer wrote:
> Hi Francis,
> Greetings
> Hans
>> it's own plugin.
>> HTH
>> Francis
Re: Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem) [message #325153 is a reply to message #325139] Mon, 11 February 2008 08:00 Go to previous messageGo to next message
And on top of Francis' advice you can also modify your plugins to
require that specific plugin version or import the specific version of
the packages. That way even if the 3rd party library still requires an
older version, unless common logging has been made a singleton both
plugins will get their required version.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem) [message #325171 is a reply to message #325139] Mon, 11 February 2008 15:13 Go to previous messageGo to next message
Hi Francis,
I have now removed all but one occurrence of the Commons Logging Library
from my code.
One of my plug-ins contains the commons-logging-1.1.jar, a custom
LogFactory implementation and a commons-logging.properties file which
activates that factory. It is furthermore exporting
org.apache.commons.logging and org.apache.commons.logging.impl.
All my other plug-ins are depending on that plug-in.
While this works, it did not solve the problem.
!ENTRY org.eclipse.ui 4 0 2008-02-11 19:02:05.701
!MESSAGE Unhandled event loop exception
!STACK 0
at org.mortbay.util.Container.<clinit>(Container.java:39)
org.eclipse.equinox.http.jetty.internal.HttpServerManager.up dated(HttpServerManager.java:78)
org.electrocodeogram.eclipse.core.logging.CommonsLogFactoryI mpl)
at org.apache.commons.logging.LogFactory$2.run(LogFactory.java: 574)
It looks as if my custom LogFactory implementation
(org.electrocodeogram.eclipse.core.logging.CommonsLogFactory Impl) can't
be accessed by some plug-in. However, the question here is why any other
plug-in would even see my Commons Logging code, as its use should be
limited to my plug-ins.
How is plug-in class loading handled in Eclipse? Would the same class,
loaded by different plug-ins share its static variables or not? I am
simply wondering whether some internal, static caching of Commons
Logging might be at the root of this problem.
Is there anything else I can do to ensure that "my" Commons Logging
library is not seen/used by _any_ plug-in which does not explicitly
depend on my logging plug-in?
Thanks a lot for your effort.
Greetings
Hans
> Francis
Re: Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem) [message #325174 is a reply to message #325171] Mon, 11 February 2008 17:08 Go to previous messageGo to next message
There is an option you can put in the bundle manifest (the MANIFEST.MF
file) which allows for the plugin to be globally shared. It's called
Eclipse-BuddyPolicy. Set it to global.
That should make it available everywhere.
I think the best thing however, is to just get the plugin from orbit and
use that. Your customizations should be in *one* of *your* plugins, not
in the commons-logging plugin. That should be pure commons-logging.
They everything that needs commons-logging should find it and get it
from the same place.
H. Meyer wrote:
> Hi Francis,
> from my code.
> !STACK 0
> at
> Greetings
> Hans
>> Francis
Re: Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem) [message #325176 is a reply to message #325174] Mon, 11 February 2008 18:03 Go to previous messageGo to next message
My customisations are basically just a custom LogFactory implementation
as well as the commons-logging.properties which activates that factory.
The problem which I am seeing with using the corresponding Orbit plug-in
is the commons-logging.properties file.
I don't quite see yet how it would be possible to restrict the use of my
custom LogFactory to only my own plug-ins. I tried putting a
commons-logging.properties file in each of my plug-ins once, but Commons
Logging did not see the file.
(Though, as is visible in the exceptions I've posted so far, my current
approach seems to fail at containing the use of my custom LogFactory too
for some reason.)
Another issue of using the orbit plug-in would be the deployment via an
Update Site. Can I just include the orbit plug-in in my own Update Site
or would the end user have to always select my update site and an orbit
update site in order to resolve the dependency?
Once again thank you for your time.
Greetings
Hans
> H. Meyer wrote:
>> Hi Francis,
>> from my code.
>> !STACK 0
>> at
>> Greetings
>> Hans
>>> Francis
Re: Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem) [message #325187 is a reply to message #325176] Tue, 12 February 2008 07:37 Go to previous messageGo to next message
I have now moved to using SLF4J instead of Commons Logging
(http://www.slf4j.org) to see whether that might solve some of my class
loading issues.
I'll keep you updated.
Greetings
Hans
Re: Commons Logging & Eclipse plug-ins (multi plug-in compatibility problem) [message #325242 is a reply to message #325176] Wed, 13 February 2008 01:35 Go to previous message
H. Meyer wrote:
> for some reason.)
Can't you set a System.property to point to the properties file? I'm
not that familiar with commons logging actually. I use it, but then I
assume it always uses log4j and set the properties of log4j directly
using their API, which works out fine.
You should be able to include it in your own update site; the
redistribution for anything provided by eclipse.org should be the same.
No problem, I have been helped many times. :)
> Greetings
> Hans
>> H. Meyer wrote:
>>> Hi Francis,
>>> from my code.
>>> !STACK 0
>>> at
>>> Greetings
>>> Hans
>>>> Francis
Previous Topic:Forms Text Wrap
Next Topic:Clearing of Workspace data
Current Time: Fri Aug 08 03:34:43 EDT 2025
Powered by FUDForum. Page generated in 0.06420 seconds
