Home » Eclipse Projects » Eclipse Platform » ProgressMonitorDialog question/feature request
ProgressMonitorDialog question/feature request [message #325048] |
Thu, 07 February 2008 00:50 |
Originally posted by: olegryaboy.myway.com
I use ProgressMonitorDialog for a task that requires waiting for response
from a remote server, so I want the progress bar to show "indeterminate"
progress (like ProgressBar(x, SWT.INDETERMINATE)).
Is there a way to do that?
I tried monitor.beginTask("xxxx", IProgressMonitor.UNKNOWN), but that just
shows a disabled, grayed out progress bar...
Thank you!
Re: ProgressMonitorDialog question/feature request [message #325072 is a reply to message #325048] |
Thu, 07 February 2008 15:35 |
Originally posted by: ad.powerflasher.de
For me "beginTask" with "IProgressMonitor.UNKNOWN" works. Maybe there is an
other problem?
"Oleg" <olegryaboy@myway.com> schrieb im Newsbeitrag
news:b8343570ed1de03192eacde511c197d9$1@www.eclipse.org...
> Thank you!
Re: ProgressMonitorDialog question/feature request [message #325170 is a reply to message #325048] |
Mon, 11 February 2008 18:55 |
Just to be clear, I expect the progress bar to show the "unknown progress"
animation, where it goes back and forth. Instead, I get a disabled, grayed
out bar, which looks like the program got "stuck".
Here's the code snippet:
// Get data from server
ProgressMonitorDialog pdm = new ProgressMonitorDialog(activeShell);
try {
pdm.run(true, false, new IRunnableWithProgress() {
public void run(IProgressMonitor monitor) throws
InvocationTargetException, InterruptedException {
monitor.beginTask("Getting data from server.",
IProgressMonitor.UNKNOWN);
monitor.subTask("Contacting server.");
monitor.worked(IProgressMonitor.UNKNOWN);
Thread.sleep(20000);
catch (InvocationTargetException e) {
e.printStackTrace();
catch (InterruptedException e) {
Re: ProgressMonitorDialog question/feature request [message #325238 is a reply to message #325170] |
Tue, 12 February 2008 23:53 |
Marcel Messages: 11 Registered: July 2009 |
Not entirely sure it'll solve your problem, but there is probably no
need to call monitor.worked for an unknown task - just call monitor.done
when you are finished, and in the meantime the progress display should
indicate that work is being done.
Marcel
> try {
Re: ProgressMonitorDialog question/feature request [message #325295 is a reply to message #325238] |
Wed, 13 February 2008 22:35 |
Marcel,
Thank you so much for replying. I tried deleting the call to
monitor.worked, and other permutations (calling worked(10), etc.), to no
avail - no animation, just a grayed out bar.
Would you mind running the code below on your computer to see if you get a
different behavior?
Thank you,
Oleg
> Marcel
>> try {
Re: ProgressMonitorDialog question/feature request [message #325317 is a reply to message #325295] |
Thu, 14 February 2008 14:45 |
Originally posted by: eclipse-news.rizzoweb.com
Have you seen this article?
http://www.eclipse.org/articles/Article-Progress-Monitors/ar ticle.html
Hope this helps,
Eric
Oleg wrote:
> Marcel,
> a different behavior?
> Thank you,
> Oleg
>> Marcel
>>> progress" animation, where it goes back and forth. Instead, I get a
>>> disabled, grayed out bar, which looks like the program got "stuck".
>>> try {
Current Time: Fri Apr 26 09:35:42 GMT 2024
Powered by FUDForum. Page generated in 0.03875 seconds
