| Accessibility: need thicker caret [message #324747] |
Thu, 31 January 2008 10:39  |
Originally posted by: noone.here.invalid
hello
I notice there's an accessibility feature for custom, supposedly thicker
caret (cursor), but it doesn't make the caret appreciably thicker, maybe
one or two pixel lines. Is there a way to get a block caret so the caret
is the size of a (monospace) character?
also, for some reason, pressing Insert has no effect whatsoever in any of
the editors. caret does not change, nor the insert mode.
| Re: Accessibility: need thicker caret [message #324782 is a reply to message #324763] |
Fri, 01 February 2008 02:27   |
Daniel Megert <daniel_megert@ch.ibm.com> wrote in
news:fnt06p$gdg$1@build.eclipse.org...
> If you are using a 3.4 build and run on Windows you can use the
> default caret and then change its appearance via the Windows
> Accessibility tools.
>> any of the editors. caret does not change, nor the insert mode.
> What editor are you talking about? Pressing Insert key works fine
> here.
I'm not sure which editor it's using, but it's the same whether I'm
editing a .css, html, .js, or .erb / .rb (ruby/rails) file.
I'm using Aptana studio (RadRails). Its eclipse version is 3.2. I tried
updating to eclipse 3.4 by pointing it to
http://download.eclipse.org/releases/ganymede/staging/
but it complained about missing com.ibm.icu. I googled and found
com.ibm.icu.source_3.6.1.v20070417.zip
but couldn't figure out how to install it. I selected new archived site
and pointed Eclipse to it but it said "does not contain an update site".
I guess I could install 3.4 standalone then install RadRails as a plugin,
but I did that before and couldn't do it and gave up and installed Aptana
which has RadRails built-in. Arggh, it shouldn't be this hard.
FUDForum. Page generated in 0.04813 seconds
