Home » Eclipse Projects » EGit / JGit » [Solved] Clone submodules in JGit(Prerequisites? Add submodules to existing clone?)
[Solved] Clone submodules in JGit [message #1684662] Wed, 18 March 2015 10:24 Go to next message
I am using JGit to clone, and I am trying to include the submodules. This is a snippet:
cloneCommand.setNoCheckout(true);
cloneCommand.setCloneSubmodules(true);
cloneCommand.call();
But the submodules weren't cloned. So I would like to ask about the prerequisites for submodules to be cloned. Does it have to be necessarily after the checkout?
also is there a simple way to add all submodules recursively to an existing clone?
[Updated on: Thu, 21 May 2015 11:50] by Moderator
Re: Clone submodules in JGit [message #1684801 is a reply to message #1684662] Wed, 18 March 2015 11:34 Go to previous messageGo to next message
Julian,
AFAIK, to clone submodules, a repository must have a working directory.
Hence the setNoCheckout() call conflicts with setCloneSubmodules(). JGit
should probably _somehow_ flag that combining these options isn't possible.
To add submodules to an existing repository, the SubmoduleUpdateCommand
can be used. It will update all registered submodules, clone missing
submodules and checkout the commit specified in the configuration.
For more details you may want to read the summary [1] I wrote some time
ago that explains what submodule commands JGit offers and what they can
be used for.
HTH
Rüdiger
[1]
http://www.codeaffine.com/2014/04/16/how-to-manage-git-submodules-with-jgit/
On 18.03.2015 15:24, Julian Enoch wrote:
> This is a snippet:
> existing clone?
Re: Clone submodules in JGit [message #1688392 is a reply to message #1684801] Fri, 20 March 2015 11:54 Go to previous messageGo to next message
Thank you Rüdiger,
Using SubmoduleUpdateCommand in couple with SubmoduleInitCommand has worked for one of my submodule. However with the second one I am dealing with a strange exception:
org.eclipse.jgit.api.errors.JGitInternalException: Creating directories for /path/directory failed
at org.eclipse.jgit.api.SubmoduleUpdateCommand.call(SubmoduleUpdateCommand.java:210)
Caused by: java.io.IOException: Creating directories for /path/directory failed
at org.eclipse.jgit.util.FileUtils.mkdirs(FileUtils.java:316)
at org.eclipse.jgit.dircache.DirCacheCheckout.checkoutEntry(DirCacheCheckout.java:1225)
at org.eclipse.jgit.dircache.DirCacheCheckout.doCheckout(DirCacheCheckout.java:451)
at org.eclipse.jgit.dircache.DirCacheCheckout.checkout(DirCacheCheckout.java:396)
at org.eclipse.jgit.api.SubmoduleUpdateCommand.call(SubmoduleUpdateCommand.java:197)
... 14 more
After some debugging, I see that when FileUtils.mkdirs tries to create directory, the latter is present in /path/ and is a broken Link!!! I don't know where it comes from. Do you have any idea??
If I clone everything using git CLI and the option --recursive, everything goes well and the directory in question is just a normal plain folder and not a Link.
Re: Clone submodules in JGit [message #1688756 is a reply to message #1688392] Sat, 21 March 2015 12:38 Go to previous messageGo to next message
Julian,
I remember that in the past, JGit did not support symbolic links [1].
This has changed but AFAIK still depends on which version of Java and
which OS you run on. Which OS/JGit/Java do you use?
If you look into the repository that was cloned with native Git, what
exactly is /path/directory?
Rüdiger
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=354367
On 20.03.2015 16:54, Julian Enoch wrote:
> Thank you Rüdiger,
> at
> failed
> at
> at
> at
> at
> ... 14 more
Re: Clone submodules in JGit [message #1689513 is a reply to message #1688756] Mon, 23 March 2015 15:27 Go to previous messageGo to next message
It seems that this is related. In fact at some point the target of the symlink is deleted and the symlink is dangling, which causes the problem.
os:
Red Hat Enterprise Linux Server release 6.4 (Santiago)
2.6.32-358.6.2.el6.x86_64
JGit:
org.eclipse.jgit (3.7.1.201502270113) "JGit Core"
Java:
java-1.7.0-openjdk-1.7.0.19.x86_64
I am not sure I understand the point of this question. /path/directory is just a plain location path.
I am not a specialist but this is my idea of what is going on. This is complicated so hang on with me:
    On the commit 5f0a7db, we have a plain folder at location1
    On the master branch, the folder has been moved to location2 and a symlink was created instead at location1
Here comes JGit:
    If I clone the plain Git repository, the branch master is checked out and everything is fine
    But If I clone it as a submodule of another repository, using JGit submodule commands, here is what happens:
    JGit first clones the branch master: so in the working tree, we have a target folder at location2 and a symlink at location1
    Then JGit tries to checkout the commit 5f0a7db (I don't know why or if this is normal). So, it deletes the target folder at location2. This results in a dangling link at location1. Then it tries to create the folder in location1. which results in an exception because of the dangling link as you can see from this code:
    package org.eclipse.jgit.util;
    public class FileUtils {
    	public static void mkdirs(final File d, boolean skipExisting) throws IOException {
    		if (!d.mkdirs()) {
    			if (skipExisting && d.isDirectory()) return;
    			throw new IOException(MessageFormat.format(JGitText.get().mkDirsFailed, d.getAbsolutePath()));
In conclusion, I think that JGit should not fail because it couldn't create the folder. Instead it should be able to delete the broken link.
Please let me know your views.
Re: Clone submodules in JGit [message #1690066 is a reply to message #1689513] Tue, 24 March 2015 18:51 Go to previous messageGo to next message
If you are using symlinks and JGit 3.7 you also need to have the org.eclipse.jgit.java7 bundle on the
class path otherwise there's no support for symlinks. Alternatively you can update to latest
4.0.0-SNAPSHOT where the java7 bundle has been merged into org.eclipse.jgit since we removed
support for Java 5 and 6.
If you can reproduce the problem with either the Java 7 bundle and running with Java 7 or higher
on a platform supporting symlinks then file a bug in Bugzilla describing the steps to reproduce the
problem.
Re: Clone submodules in JGit [message #1696090 is a reply to message #1690066] Thu, 21 May 2015 11:49 Go to previous message
Problem of symlinks gone away using JGit 3.7 and org.eclipse.jgit.java7
Previous Topic:Diff/Comparison from history for moved files does not work
Next Topic:Duplicate RevCommits in RevWalk
Current Time: Fri Nov 07 11:14:48 EST 2025
Powered by FUDForum. Page generated in 0.05462 seconds
