Application icons no longer used in SWT client [message #1681117] |
Tue, 17 March 2015 03:16  |
In our SWT client product file, we define application icons
<windowImages i16="/ch.sbb.cisi.angebot.scout.client.ui.swt/resources/icons/Ora16.png" i32="/ch.sbb.cisi.angebot.scout.client.ui.swt/resources/icons/Ora32.png" i48="/ch.sbb.cisi.angebot.scout.client.ui.swt/resources/icons/Ora48.png" i64="/ch.sbb.cisi.angebot.scout.client.ui.swt/resources/icons/Ora64.png" i128="/ch.sbb.cisi.angebot.scout.client.ui.swt/resources/icons/Ora128.png"/>
We also have the corresponding PNG files in the resource/icons directory of the swt project.
Up until a few days ago this lead to these icons being used in the following places:
- Taskbar
- Alt-Tab preview
- Top left corner of main window and login window
Since a few days, these icons are no longer shown. I am not totally sure (as I didn't notice right away) but I suspect that this coincides with our switch from Scout Luna SR1 to SR2.
Has something changed in this regard with SR2?
What would you propose to debug this?
Re: Application icons no longer used in SWT client [message #1687342 is a reply to message #1684221] |
Thu, 19 March 2015 12:09   |
I've been able to fix the problem by doing a "synchronise" and "launch" on the SWT client product. After this, the icons were back. I noticed that this caused the following information to be written into the SWT client's plugin.xml under the org.eclipse.core.runtime.products extension point:
<property
name="windowImages"
value="resources/icons/Ora16.png,resources/icons/Ora32.png,resources/icons/Ora48.png,resources/icons/Ora64.png,resources/icons/Ora128.png">
</property>
<property
name="startupForegroundColor"
value="FF8080">
</property>
<property
name="startupMessageRect"
value="15,275,280,20">
</property>
<property
name="startupProgressRect"
value="15,300,280,10">
</property>
This information (which comes form the product file) didn't used to be written to the plugin.xml but now it is. I guess this is a change in Eclipse itself, which was introduced with SR2 (and our update to Scout Luna SR2 of course included the update of Eclipse to Luna SR2).
Re: Application icons no longer used in SWT client [message #1687680 is a reply to message #1687342] |
Thu, 19 March 2015 15:03  |
@Urs:
Nice catch! Thank you for sharing. During my test yesterday, I did not notice this addition in the plugin.xml, but I observe this too (I had probably synchronized without noticing).
@Peter:
I have read your question and will try to answer it; probably in a separated thread, because your question isn't really related to this thread.
[Updated on: Wed, 01 April 2015 15:19] by Moderator
FUDForum. Page generated in 0.05008 seconds
