Home » Eclipse Projects » Eclipse Platform » Adding an item in the new / project... popup menu
Adding an item in the new / project... popup menu [message #322843] Fri, 30 November 2007 04:49 Go to next message
I would like to add an item just above the 'new / project...' menu (when
you right click on a project) , just like JDT do with an item "Java
Project".
I tried with the commonWizard option from com.prismtech.splice.navigator
without success.
Any ideas?
Re: Adding an item in the new / project... popup menu [message #322892 is a reply to message #322843] Fri, 30 November 2007 14:33 Go to previous message
Youmm P. wrote:
> Hello,
> Project".
> without success.
> Any ideas?
Use the newWizardShortcut extension point (a child of
org.eclipse.ui.perspectiveExtensions). Of course, you'll have to first
declare your wizard under org.eclipse.ui.newWizards and make sure to
mark it as project=true.
Hope this helps,
Eric
Previous Topic:How can I tell TextEditor to spell check only the desired content type/partition type?
Next Topic:Plugin crashes, unknown reason
Current Time: Fri Oct 31 04:16:01 EDT 2025
Powered by FUDForum. Page generated in 0.04336 seconds
