| hyperlink functionality : show always? [message #321119] |
Tue, 09 October 2007 11:25  |
Originally posted by: e.lynch.pilz.ie
I am implementing hyperlink functionality in a Custom Text editor. I am
using the extension points
org.eclipse.ui.workbench.texteditor.hyperlinkDetectors and
org.eclipse.ui.workbench.texteditor.hyperlinkDetectorTargets and all is
working well. On CTRL + mouse over I can see the Hyperlink and by clicking
on the Hyperlink the relevant open method is called.
My question is : Is it possible for me to view the hyperlinks all the time
in the editor using functionality like.... maybe hitting CTRL+H turning on
the hyperlinks (all hyperlinks visible in the editor) and something else to
turn them off?
Any help would be greatly appreciated!
Thanks in advance
Ev
| Re: hyperlink functionality : show always? [message #334324 is a reply to message #321138] |
Tue, 03 February 2009 05:53  |
Could the following be an acceptable implementation of a PresentationReconciler that adds hyperlinks to the text editor all times ? :
Or are there some drawbacks with this approach ?
PresentationReconciler reconciler= new PresentationReconciler() {
IHyperlinkPresenter hlp = new MultipleHyperlinkPresenter(new RGB(0, 0, 255));
public void install(ITextViewer viewer) {
super.install(viewer);
hlp.install(sourceViewer);
public void uninstall() {
hlp.uninstall();
super.uninstall();
protected TextPresentation createPresentation(IRegion damage, IDocument document) {
IHyperlink[] links = test.detectHyperlinks(sourceViewer, damage, true);
TextPresentation result = super.createPresentation(damage, document);
hlp.showHyperlinks(links);
return result;
Thanks in advance,
Laurent
Daniel Megert wrote:
> Ev wrote:
>> Hi
>> am using the extension points
>> is working well. On CTRL + mouse over I can see the Hyperlink and by
>> clicking on the Hyperlink the relevant open method is called.
>> time in the editor using functionality like.... maybe hitting CTRL+H
>> turning on the hyperlinks (all hyperlinks visible in the editor) and
>> something else to turn them off?
> This is currently not possible out of the box but of course you can
> implement your own presentation reconciler that shows links as links.
> Dani
>> Thanks in advance
>> Ev
FUDForum. Page generated in 0.02698 seconds
