Re: JNLP/webstart [message #320716 is a reply to message #320617] |
Thu, 27 September 2007 16:58 |
Andrew Niefer Messages: 990 Registered: July 2009 |
You should expect to see eclipse.jnlpGenerator calls in the generated
assemble.*.xml files in your buildDirectory, after the gather.bin.parts calls
and before the archive steps.
After a look at the code, it seems this call is conditional on the shape of the
feature, it requires jars, not folders. If the call is not there, set
"outputUpdateJars=true" in your build configuration build.properties file.
-Andrew
Ulrich Staudinger wrote:
> Even with running it almost manually:
> java -jar /home/ustaudinger/eclipse-3.2/startup.jar -application
> org.eclipse.ant.core.antRunner -buildfile
> /home/ustaudinger/eclipsetrader-build-space/./build/features /org.eclipse.pde.build.container.feature/build.xml
> -Dbuilder=/home/ustaudinger/eclipsetrader-build-space/build_ config
> -DbaseLocation="/home/ustaudinger/eclipse-3.2" -DjavacSource="1.5"
> -DjavacTarget="1.5" build.update.jar
> ... and after having modified in
> .../org.eclipse.pde.build.container.feature/build.xml ...
> <target name="build.update.jar" depends="init" description="Build the
> feature jar of: org.eclipse.pde.build.container.feature for an update
> site.">
> <echo> About to build jnlp?</echo>
> <eclipse.jnlpGenerator
> feature=" ${feature.destination}/org.eclipse.pde.build.container.featu re_1.0.0.jar "
> codebase="${jnlp.codebase}" j2se="${jnlp.j2se}"/>
> </target>
> i just see ...
> Buildfile:
> init:
> build.update.jar:
> [echo] About to build jnlp?
> BUILD SUCCESSFUL
> BUILD SUCCESSFUL
> Total time: 0 seconds
> but NO jnlp file anywhere.
> I think this is simply a bug.
> Regards,
> Ulrich.
> "Ulrich Staudinger" <us@activestocks.de> wrote in message
> news:fdajge$6sp$1@build.eclipse.org...
>> news:fdai8j$21j$1@build.eclipse.org...
>>> When i enable
>>> generateJnlp=true
>> I searched a bit more and found that, although defined, ant task
>> "eclipse.jnlpGenerator" is never called ?
>> [ustaudinger@tonga eclipse-3.2]$ find . -name "*" | xargs grep
>> Binary file ./configuration/org.eclipse.core.runtime/.mainData.1 matches
>> ./plugins/org.eclipse.pde.build_3.2.0.v20060603/plugin.xml:
>> name="eclipse.jnlpGenerator"
>> Any pointers?
>> Cheers,
>> Ulrich.
FUDForum. Page generated in 0.03073 seconds
