Re: How to Disable Breadcrumbs [message #320294 is a reply to message #320291] |
Sat, 15 September 2007 15:57 |
Originally posted by: jacek.pospychala.pl.ibm.com
David,
luckly similar question was asked on eclipse.platform.ua newsgroup just
a day or two ago:
http://www.eclipse.org/newsportal/article.php?id=97&grou p=eclipse.platform.ua#97
Chris Goldthrope said there that:
We don't have a preference for this but here is one way to do it.
Find the file org.eclipse.help.webapp\advanced\breadcrumbs.css and
replace its contents with.
..help_breadcrumbs {
display: none;
David Kyle wrote:
> Ron,
> I'm going to answer you question here since it belongs in
> Eclipse/Platform/User Assistance (ie. eclipse.platform news group).
> Sorry to hear you don't like the breadcrumb feature. The Eclipse plugin
> org.eclipse.help.webapp is responsible for dynamically injecting additional
> html. The simple answer is that you have no control over the existing
> breadcrumb feature.
> I would file a bug/feature report. Help->Report Bug, Select Eclipse.org,
> click next, select Platform, click Finish. Fill in the bug form and set
> Component to User Assistance.
> Bugs can be found at https://bugs.eclipse.org/bugs.
> By the way, the class that you are interested in is called
> org.eclipse.help.internal.webapp.servlet.BreadcrumbsFilter. It is one of
> five servlet filters being used by the Eclipse user assistance plugins (ie
> help).
> If you absolutely must remove breadcrumbs then check out the
> org.eclipse.help.webapp source code and tweak the code.
> David Kyle
> http://richclientplatform.blogspot.com/
FUDForum. Page generated in 0.03361 seconds
