Home » Eclipse Projects » Eclipse Platform » Initializing java tooling hangs at 0%
Initializing java tooling hangs at 0% [message #319627] Tue, 28 August 2007 12:45 Go to next message
Hi Folks,
I am using eclipse 3.2.2 on windows (Build id: M20070212-1330). I have 30
projects in my workspace. When I start eclipse it hangs at the point where
the active task is initializing java tooling. The only way out of this I
have found is to create a new workspace and import all my projects again.
Does anyone know what is going on here and what I can do?
Many thanks,
Miles
Re: Initializing java tooling hangs at 0% [message #319631 is a reply to message #319627] Tue, 28 August 2007 13:25 Go to previous messageGo to next message
--------------000601000509010900080909
Miles,
Maybe you can use this to see what's causing the deadlock:
http://wiki.eclipse.org/How_to_report_a_deadlock
Miles Daffin wrote:
> Hi Folks,
> 30 projects in my workspace. When I start eclipse it hangs at the
> point where the active task is initializing java tooling. The only way
> out of this I have found is to create a new workspace and import all
> my projects again.
> Many thanks,
> Miles
<html>
<head>
http-equiv="Content-Type">
</head>
Miles,<br>
<br>
Maybe you can use this to see what's causing the deadlock:<br>
<blockquote><a href="http://wiki.eclipse.org/How_to_report_a_deadlock">http://wiki.eclipse.org/How_to_report_a_deadlock</a><br>
</blockquote>
<br>
Miles Daffin wrote:
<blockquote
cite="mid:f9b204d559328f6aa28b9e50358fcde0$1@www.eclipse.org"
type="cite">Hi Folks,
<br>
<br>
30 projects in my workspace. When I start eclipse it hangs at the point
where the active task is initializing java tooling. The only way out of
this I have found is to create a new workspace and import all my
projects again. <br>
<br>
<br>
Many thanks,
<br>
<br>
Miles
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------000601000509010900080909--
Re: Initializing java tooling hangs at 0% [message #319637 is a reply to message #319627] Tue, 28 August 2007 15:40 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Miles Daffin" <miles.daffin@morganstanley.com> wrote in message
news:f9b204d559328f6aa28b9e50358fcde0$1@www.eclipse.org...
> Hi Folks,
> projects in my workspace. When I start eclipse it hangs [...]
How long does it hang for?
Are there any interesting contents in the .log file? (Under the workspace
..metadata folder.)
Some people have reported very long lags in startup of workspaces with
projects containing many (ie tens of thousands) of warnings. Don't know if
that's your situation or not.
Re: Initializing java tooling hangs at 0% [message #320814 is a reply to message #319627] Tue, 02 October 2007 10:29 Go to previous messageGo to next message
Miles,
On my platform, I'm seeing the "Initializing Java Tooling" hang at 60%
complete for perhaps 20 or 30 seconds (Eclipse 3.3, Linux Fedora Core 3 on a
fairly speedy box). It eventually completes, but it is a disconcerting
stall. In my runtime workspace where I see this behavior I actually have
*no* java related projects or source code (only 3 or 4 projects related to
my tool application), so I'm not quite sure what it is initializing for all
that time. No entries of interest appear in the workspace's .metadata/.log
file.
A quick bugzilla search did turn up a report that seems related:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=188712
We'll see where it goes,
-Pete
"Miles Daffin" wrote :
> Hi Folks,
> Many thanks,
> Miles
Re: Initializing java tooling hangs at 0% [message #320817 is a reply to message #320814] Tue, 02 October 2007 11:14 Go to previous messageGo to next message
Note this bug is about "Initializing Java tooling" taking a long time,
it is not about it hanging (ie. never completing). It is marked as
"needInfo" btw. So no progress can be made until we get more information.
If you have a case were "Initializing Java tooling" never completes, I
would suggest to enter a separate bug report, including thread dumps
to help us debug it.
Re: Initializing java tooling hangs at 0% [message #320984 is a reply to message #320817] Thu, 04 October 2007 15:11 Go to previous message
Agreed. I've posted the exceptions I've seen that may be related to the
java tooling taking a long time to initialize to that bug report; hope it
helps,
-Pete
Previous Topic:Unknown Extension Point in Linux
Next Topic:Bug in ObjectActionContributor
Current Time: Wed Oct 22 06:50:28 EDT 2025
Powered by FUDForum. Page generated in 0.05216 seconds
