Home » Eclipse Projects » Eclipse Platform » How can I hook the breakpoint view actions
How can I hook the breakpoint view actions [message #319391] Mon, 20 August 2007 09:53 Go to next message
I want to be notified when the breakpoint view actions "remove" and
"remove all" take place, so I can tell our editor to remove breakpoints.
So, my first thought was to setup a listener on the breakpoint list. But,
if I do that I will also be notified when our own editor adds or removes a
breakpoint. See the circularity here?
What I really want is some callback from the actions themselves, not the
entity that it modifies.
Is this a "fact of life" for listeners? That is, they should set a bit to
protect against circularities, turn off certain listeners, etc.? Or, is
there a more elegant way to do this?
We don't use the ruler (gutter decoration) stuff in Eclipse editor
classes, we have our own gutter. Although our editor does extend the
TextEditor and SourceViewer, etc.
Re: How can I hook the breakpoint view actions [message #319417 is a reply to message #319391] Mon, 20 August 2007 13:46 Go to previous messageGo to next message
If you can find commands, you can register a listener with the
ICommandService that will notify you of execution. For example, I see
org.eclipse.debug.ui.commands.RemoveAllBreakpoints (I found it in the
Plug-in Registry view).
In 3.3 that will tell you when that command is executed (usually via a
keybinding), but will not notify you if the user presses the toolbar
version (except in a few cases).
Later,
PW
Paul Webster
Re: How can I hook the breakpoint view actions [message #319449 is a reply to message #319391] Tue, 21 August 2007 11:25 Go to previous message
Use IBreakpointListener to listen to breakpoint additions/removals. However,
if your editor already has a "marker annotation model" then breakpoints will
appear/disappear from your ruler automatically based on the resources the
markers are associated with, and the line number attribute on the marker.
See these for more information:
http://www.eclipse.org/eclipse/debug/documents/ec_2007/Debug _Tutorial_2007.pdf
http://www.eclipse.org/articles/Article-Debugger/how-to.html
Darin
"Farokh Morshed" <fmorshed@curl.com> wrote in message
news:2b7fc94c72b16f68d0e004a81493b533$1@www.eclipse.org...
>I want to be notified when the breakpoint view actions "remove" and "remove
>all" take place, so I can tell our editor to remove breakpoints. So, my
>first thought was to setup a listener on the breakpoint list. But, if I do
Previous Topic:Text hovers for all editors
Next Topic:Navigator rename bug
Current Time: Fri Nov 07 20:36:50 EST 2025
Powered by FUDForum. Page generated in 0.05449 seconds
