| Eclipse Guidelines [message #32222] |
Mon, 03 April 2006 01:36  |
Originally posted by: a.hoess.bachmann.info
Hi all,
the Eclipse Guidelines are not really up to date (from 02/2004)! I'm
interested in these Guidelines and should know when the next update of
this article is planned.
Thanks and Greets,
Alexander
| Re: Eclipse Guidelines [message #33043 is a reply to message #32793] |
Tue, 18 April 2006 20:28  |
On Tue, 11 Apr 2006 08:53:37 -0400, Eclipse WebMaster (Denis Roy)
<webmaster@eclipse.org> wrote:
>> For an out-of-date document what is the policy for allowing others to
>> update such articles? Can someone who is not the original author of a
>> document update it?
And, its even better than Denis describes for these UI Guidelines
guidelines.
The "old" document was converted to the Eclipse Wiki, to make it easier to
collaborate on
updates.
http://wiki.eclipse.org/index.php/Development_Conventions_an d_Guidelines
If you are in a position to "own" part of the guidelines, and are a
committer, you can update
that wiki page directtly. If you are not in a position to "own" part of
it, you can add to the
discussion page, and, ideally, just include a little section of what you'd
suggest.
And ... not sure ... I think "write" access to that wiki still requires a
committer id and password
... if so, bugzilla entries with suggested content would be good ... or
.... open a bug to fix the
access restriction? :)
FUDForum. Page generated in 0.50462 seconds
