Re: EMFStore vs. CDO [message #1678800 is a reply to message #1668743] |
Mon, 16 March 2015 10:45 |
Jonas Helming Messages: 699 Registered: July 2009 |
Hi Franco,
I think it makes sense to define your requirements more in detail. Examples:
- Number of Users?
- Expected Model Size?
- Online vs. Offline?
- How should conflicts be handled?
- and many more
based on that I would spend some time on an evaluation to make sure you
find the best technology for your use case. Depending on the kind of
application you develop, there is even a third alternative: Git in
combination with EMF Compare.
About the scalability of concurrent Users in EMFStore: As the default
Mode in EMFStore is offline, the server only gets active, once a user
(or a system) triggers a commit or update. Of course it depends on the
total number of users, you want to support, but typically the model size
is a more critical factor. If you need to support very large model
instance (millions of elements), the loading and unloading feature of
CDO can help.
Best regards
Jonas
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Am 13.03.2015 um 06:02 schrieb Franco Lombardo:
> Hi all,
> I'm choosing the persistence engine for a project that uses EMF, and I'd
> like to know if I should use EMFStore or CDO. Consider that in my use
> case this engine will be heavily used by many concurrent clients, so
> scalability could be an issue.
> I did some test with CDO and the MongoDBStore, because I thought to use
> the scalability features of this DB, but it seems to me that this
> project is not longer supported, isn't it?
> Thank you very much.
> Franco
FUDForum. Page generated in 0.06087 seconds
