Re: Deploying Workflow Model Using Console Command [message #1668889 is a reply to message #1668551] |
Thu, 12 March 2015 17:36 |
the path to the model file is typically relative to the folder from where you're executing the command. But I think an absolute path should work as well.
Since you can log in to the portal, have you considered deploying it from there?
Go to the "Administration" perspective (top left drop down) and then to the "Model Management" View (in the left navigation menu). You'll find a "Deploy" option there.
Jan
Re: Deploying Workflow Model Using Console Command [message #1670649 is a reply to message #1668889] |
Fri, 13 March 2015 09:26 |
Lea-Louisa Maass Messages: 3 Registered: March 2015 |
deploying the model in the portal works fine, but since I am trying to set up the engine and deploy models automatically, I need to use the console command.
When putting the .xpdl-File in the same folder as the one where I start the command from, I get a NullPointerException:
2015-03-13 08:28:11,115 INFO [main] () log.extensions - Initializing static extensions resolver
2015-03-13 08:28:11,116 INFO [main] () log.extensions - Initializing Service Provider extensions resolver
2015-03-13 08:28:11,116 INFO [main] () log.extensions - Using extensions manager: org.eclipse.stardust.engine.core.runtime.beans.PartitionAwareExtensionsManager@368239c8
2015-03-13 08:28:11,720 WARN [main] () log.LogUtils -
at org.eclipse.stardust.common.config.Version.compareTo(Version.java:173)
at org.eclipse.stardust.common.config.Version.compareTo(Version.java:159)
at org.eclipse.stardust.common.config.Version.compareTo(Version.java:28)
at org.eclipse.stardust.common.CompareHelper.compare(CompareHelper.java:100)
at org.eclipse.stardust.engine.core.model.beans.ElementFactoryImpl.createModel(ElementFactoryImpl.java:1169)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader$InvocationManager.invoke(DefaultXMLReader.java:1792)
at com.sun.proxy.$Proxy0.createModel(Unknown Source)
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader.loadModel(DefaultXMLReader.java:613)
at org.eclipse.stardust.engine.core.model.xpdl.XpdlUtils.loadXpdlModel(XpdlUtils.java:629)
at org.eclipse.stardust.engine.core.model.xpdl.XpdlUtils.loadXpdlModel(XpdlUtils.java:598)
at org.eclipse.stardust.engine.cli.console.DeployCommand$ModelFile.<init>(DeployCommand.java:536)
at org.eclipse.stardust.engine.cli.console.DeployCommand.readModelsFromFile(DeployCommand.java:602)
at org.eclipse.stardust.engine.cli.console.DeployCommand.run(DeployCommand.java:197)
at org.eclipse.stardust.common.utils.console.DefaultConsoleProcessor.execute(DefaultConsoleProcessor.java:128)
at org.eclipse.stardust.engine.cli.console.Main.run(Main.java:84)
at org.eclipse.stardust.engine.cli.console.Main.main(Main.java:73)
2015-03-13 08:28:11,723 WARN [main] () console.DefaultConsoleProcessor - Operation could not be performed: null
at org.eclipse.stardust.engine.core.model.beans.DefaultXMLReader.loadModel(DefaultXMLReader.java:615)
Do you have any idea where the problem is?
Best Regards,
Lea-Louisa
FUDForum. Page generated in 0.03515 seconds
