Home » Language IDEs » C / C++ IDE (CDT) » CDT for Win2000??
CDT for Win2000?? [message #32180] Thu, 16 May 2002 06:49 Go to next message
Hello all,
I'm very new to the CDT project.
I'm using Eclipse and the JDT a lot on Windows2000.
I can't find the CDT download for Windows, isn't there one?
Mark
Re: CDT for Win2000?? [message #32220 is a reply to message #32180] Thu, 16 May 2002 08:48 Go to previous messageGo to next message
There is no special download for Windows. You can use the downloads found at http://www.eclipse.org/cdt. Much of the
CDT function will work on Windows, but in some cases we are leveraging Linux system tools for things like debugging
(gdb), autoconf support, and profiling (gprof). So this function will not work "out of the box" on Windows.
However, installing the cygwin toolkit (http://www.redhat.com/download/cygwin.html) which is a Unix environment for
Windows gets you some of this function on Windows.
Hope that helps, and by the way, you just made our user FAQ:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/user/faq.html?cvsroot=Tools_Project#install_30
Jeff.
"mark evertz" <mark.evertz@gmx.de> wrote in message news:ac027b$iop$2@rogue.oti.com...
> Hello all,
> Mark
Re: CDT for Win2000?? [message #32255 is a reply to message #32180] Thu, 16 May 2002 08:42 Go to previous messageGo to next message
mark evertz wrote:
> Hello all,
> Mark
There is no special drop for Windows. It should (not supported though)
work on Windows as is. On the other hand there are some tools that CDT
assumes are available, and they are found in cygwin. See some older
appends on this subject.
Robert.
Re: CDT for Win2000?? [message #32536 is a reply to message #32220] Thu, 16 May 2002 12:21 Go to previous messageGo to next message
I had much the same question a couple of days ago ... but didn't get around
to asking:) I did, however, download CDT and found that most of what you
say is correct; cygwin does provide the functionality needed. There were 2
anoloies I noted, however:
1) When Eclipse booted with CDT installed a shell window appeared and never
went away. Don't know where it came from - any ideas?
2) Debugging/Running did not work - seemed to produce a violation (can't
remember now) in the target process that poped up a "... you ought to save
and exit" warning from Eclipse itself. I suspect this has something to do
with cygwin's gdb implementation. If you open a cygwin shell and type 'gdb'
you get a tk/tcl wrapper much like what Eclipse is trying to do itself. Any
other ideas?
All in all I'd like to see this work as well and would put in some time to
make it happen. I'm an Eclipe novitiate and got involved because I have a
use to GEF plugin. I'm also a C hack and an integrated Java/C/C++
environment would be real sweet.
One final comment - with CDT installed I seemed to get stack overflow errors
from the VM with alarming regularity. I have since uninstalled and this
problem is no more.
Hope this helps,
Al
"Jeff Turnham" <turnham@ca.ibm.com> wrote in message
news:ac09dt$m09$1@rogue.oti.com...
> Jeff.
> > Hello all,
> > Mark
Re: CDT for Win2000?? [message #32569 is a reply to message #32536] Thu, 16 May 2002 13:58 Go to previous messageGo to next message
Yes...that window is from a "ps" command we are kicking off to feed our "Process Monitor" view. You can safely close
the shell Window. We will look into making that Window "go away".
> other ideas?
Can you provide the error message you encountered. Also can you do the following 2 things to test gdb:
1. Do a "gdb -version" and let us know the version number and build date.
2. Try using gdb from the command line with the -nw flag (No Window) which is how we use it. "gdb -nw yourExe". Can
you tell us if this works and if you can do the normal things like stepping.
If you can "put in some time", and are going to get into the code I would suggest subscribing to the appropriate CDT
mailing list. This is where design\code discussions happen. Comments on usabilty and user experience are just fine on
this newsgroup.
> problem is no more.
This is one we haven't heard before...Can you provide the stack (if there is one)...Could be in the .log file.
> Hope this helps,
> Al
Yep all comments help ;-) Thanks...
Jeff,
Re: CDT for Win2000?? [message #33071 is a reply to message #32569] Fri, 17 May 2002 11:35 Go to previous messageGo to next message
Jeff,
Reloaded CDT and poked around a bit - came up with the following:
(can't
save
do
'gdb'
Any
> > other ideas?
Checked this out and it would appear to have been a mistake in the launch
configuration - FALSE ALARM
to
a
errors
> > problem is no more.
Haven't had it insatlled long enough to confirm or deny. Will monitor.
Now that I've cleaned up my launch configuration I do not have an error but
the debugger still does not seem to work for me. I've confirmed 'gdb -nw'
works from the command line (version is GNU gdb 5.0 (20010428-3)) but if I
try to debug under CDT I do not seem to be able to set a breakpoint. The
debug view appears, a new command widow pops up, there is a delay, the new
window disappears, and the indication is that the process is terminated.
Looks like this may be a problem attaching to the running process. The
default invocation of 'ps' under cygwin produces an extra column that lists
the windows id. If you're parsing ps output then it might not be what you
would expect. I also launched my test program and then tried to attach to
it. In this case the pid of the running test program is not listed which I
try to create a new attach configuration. I am suspicious of the process
list.
Thanx,
Al
Re: CDT for Win2000?? [message #33106 is a reply to message #33071] Fri, 17 May 2002 12:44 Go to previous messageGo to next message
Allan Clearwaters wrote:
> Jeff,
> (can't
> save
> do
> 'gdb'
> Any
> > > other ideas?
> to
> a
> errors
> > > problem is no more.
> list.
The proces list comes from parsing the output of ps commands. On Linux this is
fine, but on Windows, we can only do this with the cygwin ps command.
Unfortunately, cygwin ps doesn't give the same kind of information that you
would get from Linux. Perhaps there's another way to get this info on Windows,
or there are different flags we can use for ps. If you want to try out
different flags, you can test them by editing the following file:
org.eclipse.cdt.dstore.miners/org/eclipse/cdt/dstore/miners/ processmonitor/ProcessMonitorMiner.properties.
Also the Windows approach has problems because, in order to launch a shell to
run ps commands, we use Runtime.exec(). On Windows, this ends up showing a DOS
window - hence the annoying window that doesn't go away when running CDT on
Windows. Does anyone know how we can hide this?
> Thanx,
> Al
Re: CDT for Win2000?? [message #33140 is a reply to message #33071] Fri, 17 May 2002 12:37 Go to previous messageGo to next message
Hi Allan,
I was hoping that your problem would simply be with the operation of gdb in your cygwin environment, but if you can use
gdb from the command line successfully from the command line then there is more to it. To be honest, we don't claim
support for the CDT on Windows. We are focused on Linux and are using all of our cycles to drive towards a stable
release of the CDT shortly after Eclipse provides it's R2 Release. We would really like to see your problem solved, but
cannot commit to doing it ourselves. We are however, willing to receive and incorporate code submissions from the
community that fix problems like these.
For a better explanation: See the following answer in our FAQ:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/user/faq.html?cvsroot=Tools_Project#general_60
Thanks.
Jeff.
"Allan Clearwaters" <allan@object-forge.com> wrote in message news:ac37b4$16p$1@rogue.oti.com...
> Jeff,
> (can't
> save
> do
> 'gdb'
> Any
> > > other ideas?
> to
> a
> errors
> > > problem is no more.
> list.
> Thanx,
> Al
Re: CDT for Win2000?? [message #33175 is a reply to message #33071] Fri, 17 May 2002 12:37 Go to previous messageGo to next message
Works in the sense that it attaches and you can set a breakpoint?
> but if I
In order to figure out what is happening, we need some more info: while
you are
in the debug perspective, go to
Window -> Show View -> Other... -> C++ -> Output
Rerun your trial and append here what comes out in the Output View.
> The
> list.
You can type in the pid number, see if it works any better.
Robert.
Re: CDT for Win2000?? [message #33244 is a reply to message #33175] Sat, 18 May 2002 10:24 Go to previous messageGo to next message
Robert,
Thanks for the output window tip - that's solved the problem. GDB was
choking on the fact that I had a space in the path to my executable (was in
the 'My Documents' directory). Moved it and all appears well.
Thanx,
Al
Re: CDT for Win2000?? [message #33279 is a reply to message #33106] Sat, 18 May 2002 10:29 Go to previous message
David,
Regarding the problem of the sticking window, is it possible to pass the
execution engine a shortcut rather than the program name itself? If so,
then the shortcut can be set to close when the program terminates.
Al
"David McKnight" <dmcknigh@ca.ibm.com> wrote in message
news:3CE5336B.EA66F992@ca.ibm.com...
> > Jeff,
> > (can't
to
> > save
to
> > do
type
> > 'gdb'
itself.
> > Any
> > > > other ideas?
launch
time
> > to
have
> > a
overflow
> > errors
this
> > > > problem is no more.
there
but
'gdb -nw'
I
The
new
lists
you
to
which I
process
> > list.
this is
you
Windows,
to
a DOS
on
> > Thanx,
> > Al
Previous Topic:Better handling of tabs (how to?)
Next Topic:Exception on debug app?
Current Time: Fri Oct 31 21:50:13 EDT 2025
Powered by FUDForum. Page generated in 0.42612 seconds
