Home » Eclipse Projects » Mylyn » Editor management causing problems
Editor management causing problems [message #32172] Tue, 02 October 2007 10:00 Go to next message
We have an Eclipse editor that implements an SSH Terminal client that
we use to work on remote servers. A problem we have is that when we
activate tasks Mylyn will close this editor in addition the regular
ones. Is there something we can do to fix this? It does not seem
unreasonable that you might have editors that are not for local
resources and I cannot see why Mylyn should close those.
I am not sure what API's exist that Mylyn could use to figure this out.
If you have reasons to not consider this, can you think of any code we
could put in our editor to stop you from closing us?
Mark
Re: Editor management causing problems [message #32242 is a reply to message #32172] Tue, 02 October 2007 17:10 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
Yup, you just need to implement IContextAwareEditor and return false for
canClose(). I just updated the wiki docs to make this clear:
http://wiki.eclipse.org/Mylyn_Integrator_Reference#Task-Focu sed_UI
Note that if this method meets your needs you should create a bug report
for making it API, since that class is currently internal.
The best place for this kind of question is currently the
mylyn-integrators mailing list, so CC'ing.
Mik
Mark Phippard wrote:
> We have an Eclipse editor that implements an SSH Terminal client that we
Re: Editor management causing problems [message #32277 is a reply to message #32242] Tue, 02 October 2007 17:25 Go to previous message
Is it possible to use "adaptable" mechanisms instead of explicitly
implementing Mylyn API?
regards,
Eugene
> for canClose(). I just updated the wiki docs to make this clear:
> report for making it API, since that class is currently internal.
> Mik
>> we could put in our editor to stop you from closing us?
Re: Editor management causing problems [message #583014 is a reply to message #32172] Tue, 02 October 2007 17:10 Go to previous message
Mik
Re: Editor management causing problems [message #583029 is a reply to message #32242] Tue, 02 October 2007 17:25 Go to previous message
regards,
Eugene
> Mik
Previous Topic:Mylyn: Where did "Activity Report" go??
Next Topic:important: bugs.eclipse.org is failing for updating attributes
Current Time: Sun Nov 09 10:02:58 EST 2025
Powered by FUDForum. Page generated in 0.39145 seconds
