Home » Eclipse Projects » Orbit » How it works
How it works [message #2756] |
Mon, 10 July 2006 22:35 |
Originally posted by: grahame.jivamedical.com
This is a great project idea. I really approve.
It impacts strongly on the OHF project - we
have quite a lot of dependencies.
One thing that's not clear from the project charter
is exactly how it works. It ways that the orbit
project doesn't do development - so how does the
actual development happen? If I have dependency on
a particular jar, I have to work with [some folks?]
to clarify what I am actually doing, and then [I?]
commit the agreed package to the orbit bundles?
Grahame
Re: How it works [message #2793 is a reply to message #2756] |
Tue, 11 July 2006 04:38 |
David Williams Messages: 722 Registered: July 2009 |
On Mon, 10 Jul 2006 18:35:51 -0400, Grahame Grieve
> project doesn't do development - so how does the actual development
Yep, that's pretty much it. (packages could be contributed, as
well, by non-committers, eventually, if necessary, by the usual method
of attachments to bugzillas).
The important thing to remember, though, is this orbit project is
only for "third party" packages (meaning "non-eclipse"). Which I mention
only because I don't know if that's the only dependancy complication you in
Open Health Care would have. And that's why the charter says "no
developement" ...
its sort of a "packaging only" project.
The context of this proposal is recent experiences with the Callisto
release. One obvious problem that came up first was that several Eclipse
projects were
"re-shipping" the same third party packages/jars. At a minimum, this
causes "bloat". At worst, there were some projects that were actually
shipping
similar but different versions of the same third party packages, which may
have had
slightly different content, which has the
potential to cause conflicts or untested installations.
So, that situation was improved, in Callisto release, by agreement
betweeen projects
of which would project would provide the "callisto version" of the third
party packages.
But the next obvious
problem was that even then there's some differences about the way the
different projects
were "building" or "getting" these dependancies.
So, this orbit project has
the modest goal of "centralizing" the solutions to these very specific
problems.
In some sense, doing what the Callisto projects did, but in one place,
hopefully coming up
with some "best practices", etc. in the process.
Hope this helps
Re: How it works [message #2936 is a reply to message #2793] |
Tue, 11 July 2006 12:06 |
thanks
it's an unusual project if committers generally have commit rights.
Anyhow, the current OHF dependency list, all of which appear to be
candidates for this project, is:
org.apache.axis
org.apache.log4j
org.apache.commons
org.xmlpull.v1
There will be lot's more - that's only what we know, and the xmlpull
package is still awaiting EMO approval
> So, this orbit project has the modest goal of "centralizing" the
> solutions to these very specific problems.
yep, thoroughly approve of that.
Grahame
Re: How it works [message #4109 is a reply to message #2936] |
Wed, 12 July 2006 17:34 |
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
Grahame Grieve wrote:
> thanks
The idea is that teams that have the need to use a lib would be doing
the work to bundle so why not contribute that to Orbit. To facilitate
this it would be convenient for them to be committers on Orbit. We
don't want to end up with hundreds of people but, for example, it might
be one or two per project. This is somewhat unusual but not prohibited
if you consider that someone coming to add a lib is coming with an
initial contribution.
> org.apache.axis
> org.apache.log4j
> org.apache.commons
> org.xmlpull.v1
Great. Thanks. I will start pulling together a list of the initial
libs/bundles.
Jeff
Re: How it works [message #560754 is a reply to message #2756] |
developement" ...
projects were
shipping
have had
betweeen projects
party packages.
different projects
problems.
hopefully coming up
Hope this helps
Re: How it works [message #560845 is a reply to message #2793] |
Grahame Grieve Messages: 76 Registered: July 2009 |
Member |
thanks
org.apache.axis
org.apache.log4j
org.apache.commons
org.xmlpull.v1
Grahame
Re: How it works [message #560994 is a reply to message #2936] |
Jeff McAffer Messages: 104 Registered: July 2009 |
> thanks
> org.apache.axis
> org.apache.log4j
> org.apache.commons
> org.xmlpull.v1
libs/bundles.
Jeff
Current Time: Fri Apr 26 15:28:06 GMT 2024
Powered by FUDForum. Page generated in 0.04190 seconds
