Home » Archived » Buckminster » No suitable provider for component org.eclipse.license:eclipse.feature
| No suitable provider for component org.eclipse.license:eclipse.feature [message #1666063] |
Wed, 11 March 2015 10:20  |
Hi!
I'm at my wit's end... My Buckminster-based build worked nicely, until today when I updated my Eclipse installation to 4.4.2. I get the error below, but that repository contains a feature with a matching version number.
Buckminster hasn't changed, it's 1.6.0. It feels very disturbing to have a setup that suddenly doesn't work anymore. Additionaly, there is no clue where the problem is.
For some reason, I couldn't revert my installation, I'm working on that to see if the problem was caused by the upgrade or something else. In the meantime, any suggestions on how to find out what is going on? This isn't the first time something like this happens to me, but I never know which ones of my desperate attempts at recovery worked... Why is Buckminster so sensitive to the environment?
best regards,
Vlad
ERROR [0007] : No suitable provider for component org.eclipse.license:eclipse.feature/[1.0.1.qualifier,1.0.1.qualifier] was found in searchPath eclipse
ERROR [0007] : Rejecting provider p2({0}[http://download.eclipse.org/cbi/updates/license/]): No component match was found
| Re: No suitable provider for component org.eclipse.license:eclipse.feature [message #1666180 is a reply to message #1666063] |
Wed, 11 March 2015 11:21   |
I suspect you had an accidentally working solution, that stopped
accidentally working.
My recollection is that the org.eclipse.license versioning has never
worked with Buckminster. Consequently OCL and QVTd builds at least get
org.eclipse.license from
<rm:locator pattern="^org\.eclipse\.license.*"
searchPathRef="license-source-code"/>
<rm:searchPath name="license-source-code">
<rm:provider componentTypes="eclipse.feature" readerType="git">
<rm:property key="git.remote.uri"
value="/gitroot/cbi/org.eclipse.license.git"/>
<rm:property key="git.auto.fetch" value="true"/>
<rm:uri format="{0},{1}">
<bc:propertyRef key="git.license.local.repository.location"/>
<bc:propertyRef key="buckminster.component"/>
</rm:uri>
</rm:provider>
</rm:searchPath>
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=432841
and https://bugs.eclipse.org/bugs/show_bug.cgi?id=431255
Ed Willink
On 11/03/2015 14:20, Vlad Dumitrescu wrote:
> Hi!
> number.
> best regards,
> Vlad
| Re: No suitable provider for component org.eclipse.license:eclipse.feature [message #1694234 is a reply to message #1666180] |
Sun, 03 May 2015 04:54   |
Hi Ed,
I have tried the buckminster instructions you have provided, but getting the following errors:
ERROR [0002] : No suitable provider for component org.eclipse.license:eclipse.feature was found in searchPath license-source-code
ERROR [0002] : Rejecting provider git({0},{1}[null,org.eclipse.license]): No component match was found
ERROR Git repository path "null" is not absolute
The feature references the shared feature as follows:
license-feature="org.eclipse.license"
license-feature-version="0.0.0"
I am on build.eclipse.org.
Do you have any hints?
Thanks.
Ed Willink wrote on Wed, 11 March 2015 16:21Hi
</rm:uri>
</rm:provider>
</rm:searchPath>
Ed Willink
> Hi!
> number.
> best regards,
> Vlad
| Re: No suitable provider for component org.eclipse.license:eclipse.feature [message #1694235 is a reply to message #1694234] |
Sun, 03 May 2015 05:49  |
It seems that I have missed to set up the checkout directory (propertyRef git.license.local.repository.location)
Thanks, Ed for the instructions. They have helped me to make use of the shared licence feature using buckminster build.
Erdal Karaca wrote on Sun, 03 May 2015 10:54Hi Ed,
Thanks.
Current Time: Fri Nov 07 09:37:01 EST 2025
Powered by FUDForum. Page generated in 0.04291 seconds
