| EMF/GMF visual editor generation - Changing the containment of elements [message #317994] |
Wed, 18 July 2007 08:30  |
Originally posted by: lamda_hh.yahoo.de
Hey hi,
I am currently working on some sort of repository system for EMF objects.
I encounter a problem, where I have a set of EMF elements (C) which are logically contained in an EMF element A.
However, this should only be a view, phsyically I want those elements C to be saved in an EMF object B. I would save references between the Cs and the A later too, in order to be able to reconstruct the complete view transparently.
Both EMF elements, A and B, have such containment features and are be capable of holding the EMF objects C.
I have used the EMF / GMF generator chain to create the visual editor based on my ecore model. The initial idea was to create the visual editor for the "view" containment and change its editingPolicies and other classes so that they point to the Object B and thus save the Elements there.
Unfortunately it is not working, once I place elements on the pane, the are not drawn and not reflected in the xmi file. Somewhere I am missing an important detail.
I have tried a lot of other variations and was not able to succeed. By now I am running out of ideas.
So, if you have any, please help!
- thanks.
NyenVanTok
| Re: EMF/GMF visual editor generation - Changing the containment of elements [message #317999 is a reply to message #317994] |
Wed, 18 July 2007 09:41   |
NyenVanTok,
Your question sounds specific to GMF, so I've replied to include the GMF
newsgroup in the "to" list of the reply. This should bring the question
to the attention of the correct people and a subsequent reply should
appear on both newsgroups. Please direct future GMF-specific questions
directly to the GMF newsgroup.
nyenvantok wrote:
> Hey hi,
> - thanks.
> NyenVanTok
| Re: EMF/GMF visual editor generation - Changing the containment ofelements [message #318431 is a reply to message #318306] |
Sun, 29 July 2007 08:23  |
Hey Alex,
thanks for your reply.
I have to admit, my description was imprecise. Let me try again:
I have a somewhat huge metamodel. Among the elements are the elements World which should function as general containment container for the following two (and more) elements: Haystack and needlestack which both are able to pick up needles (containment).
Now, I have generated a visual editor for the haystack. So far so good. The problem is, since the haystack is the diagram root, the whole diagram is serialized in a XMI file with the root element haystack.
Now I have to do the following: I want the diagram to look like the haystack diagram, but instead of writing the needles to the haystack element, they have to be saved to the needlestack which is contained in the world element (so other editors for the metamodel can use the elements too).
The foundations of the problem are the following: The needlestack should function as repository for my needles. At some time I need some needles to modify them in the haystack editor (or wire them or something else). Obviously, I dont want the other thousands of needles in there too. Neither do I want other elements such as X, Y, Z to appear in the diagram. So its a view on a subset of elements.
What you've suggested might work. But my task imposes the problem of adding the world element as root (and probably ignoring "unknown" elements such as X, Y, Z during load time).
If you've got any more suggestions...? I'd be happy to hear them. :-)
FUDForum. Page generated in 0.06973 seconds
