Home » Eclipse Projects » Eclipse Platform » [Databinding] MasterDetail Questions, ...
[Databinding] MasterDetail Questions, ... [message #317988] Wed, 18 July 2007 05:19 Go to next message
1. MasterDetail
I just took a look at the current MasterDetail structure and have some
questions.
BeansObservables.observeDetailList() returns an List which is not
writeable although at the low-level it is because the list under the
hoods is a JavaBeanObservableList the problem is DetailObservableList
throwing an UnsupportedException.
I admit I haven't fully understood the whole thing and maybe there are
reasons not to do this kind of thing (See 2.).
How do you suggest doing things like this? Currently I'm adding the new
object to the parent observable and afters recreating the input for the
detail.
2. JavaBeanObservableList:
The List is created with an empty new arraylist and if your POJO returns
a colllection the content is copied from the original collection to new
empty array.
But now you get into trouble because when calling add/remove the entries
are not added to the original collection. This might be ok but then you
can make the list writeable by providing add/... methods. Because
JavaBeanObservableList is the underlying list in MasterDetail this might
be the possibility that the returned list should not be writeable.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Databinding] MasterDetail Questions, ... [message #318432 is a reply to message #317988] Sun, 29 July 2007 12:00 Go to previous message
Tom Schindl wrote:
> 1. MasterDetail
> questions.
> detail.
> empty array.
> Tom
Tom, can you log bugs about these?
-brad
Previous Topic:EMF/GMF visual editor generation - Changing the containment of elements
Next Topic:Advice request - removing old plugin
Current Time: Fri Nov 07 20:36:47 EST 2025
Powered by FUDForum. Page generated in 0.05151 seconds
