Home » Archived » XML Schema Definition (XSD) » XSDResourceImpl.save help
Re: XSDResourceImpl.save help [message #32034 is a reply to message #31999] |
Tue, 28 October 2003 18:53 |
Lance,
The name of the attribute is base, not baseType. Could that be the problem?
Lance Phillips wrote:
> Ed,
> I'm working on an effort to read in some of our old xmi models into
> eclipse. One of the models I'm working on is an XSD Simple Datatypes model.
> It constists of a schema and a bunch of XSDSimpleTypes. The reader seems to
> read everything in fine. I can iterate through the resouce after reading
> everything into the XSDResource and verify that the read was successful.
> However, when I try to save the resource many of the attributes are getting
> lost. In particular, the baseType attributes are all getting lost and end
> up as null. This model is completely self contained, so there is no issue
> with imports.
> Any ideas?
> thanks,
> lp
Re: XSDResourceImpl.save help [message #32068 is a reply to message #32034] |
Tue, 28 October 2003 18:57 |
Lance Phillips Messages: 210 Registered: July 2009 |
Nope... I was just using our terminology... I'm getting base="null". I
suspect this has something to do with targetNamespaces, but I can't figure
out how yet. I tried removing all target namespaces, which should work for
an entirely self contained schema, but that doesn't fix it either.
The other major item that is missing is all the facet info. I'm hoping
solving problem one, will solve problem 2, but I'm not overly optimistic at
this point.
thanks,
lp
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3F9EBB29.3779DBC0@ca.ibm.com...
> Lance,
problem?
> > Ed,
model.
seems to
reading
getting
end
issue
> > with imports.
> > Any ideas?
> > thanks,
> > lp
Re: XSDResourceImpl.save help [message #32104 is a reply to message #32068] |
Tue, 28 October 2003 19:08 |
Can you tell me how the uri fragments are determined when writting out the
references? I tried putting a breakpoint in the XSDResourceImpl's
getURIFragment method, but it never gets hit.
thanks,
lp
"Lance Phillips" <lphillips@metamatrix.com> wrote in message
news:bnme5o$uih$1@eclipse.org...
for
> this point.
> thanks,
> lp
> > Lance,
> problem?
> > > Ed,
into
> model.
> seems to
> reading
successful.
> getting
> end
> issue
> > > with imports.
> > > Any ideas?
> > > thanks,
> > > lp
Re: XSDResourceImpl.save help [message #32140 is a reply to message #32068] |
Tue, 28 October 2003 19:40 |
Lance,
Of course showing me the schema would allow me to make more informed comments.
> this point.
> thanks,
> lp
> > Lance,
> problem?
> > > Ed,
> model.
> seems to
> reading
> getting
> end
> issue
> > > with imports.
> > > Any ideas?
> > > thanks,
> > > lp
Re: XSDResourceImpl.save help [message #32175 is a reply to message #32104] |
Tue, 28 October 2003 19:45 |
Lance,
I think you mean the get eURIFragmentSegment method. This method is only used
if you have an "XMI" reference into an XSD instance; it isn't used by the XSD
model to serialize it's own instances. Calls to niceSetAttributeURIValue are
used to produce the QName references that are used internally by the XSD model
to reference things...
> thanks,
> lp
> for
> at
> > this point.
> > thanks,
> > lp
> > > Lance,
> > problem?
> > > > Ed,
> into
> > model.
> > seems to
> > reading
> successful.
> > getting
> > end
> > issue
> > > > with imports.
> > > > Any ideas?
> > > > thanks,
> > > > lp
Re: XSDResourceImpl.save help [message #32210 is a reply to message #32068] |
Tue, 28 October 2003 20:10 |
OK... figured out the base type problem. I was not setting the names of the
types until I was done reading everything in. I did it as a post processing
step. Thus, all the uris where getting created as Q1:null, even though the
type referenced the correct entity.
Shouldn't setting the name of the type have caused the corresponding uri
values to be recalculated?
thanks,
lp
for
> this point.
> thanks,
> lp
> > Lance,
> problem?
> > > Ed,
into
> model.
> seems to
> reading
successful.
> getting
> end
> issue
> > > with imports.
> > > Any ideas?
> > > thanks,
> > > lp
Re: XSDResourceImpl.save help [message #32245 is a reply to message #32210] |
Tue, 28 October 2003 20:24 |
Lance,
Doing the dependency analysis after a name change to update the serialization of
all references would be possible, but the model doesn't do that right now.
Calling XSDConcrete.updateElement on your schema at the end is a brute force way
to ensure that everything is up to date.
> thanks,
> lp
> for
> at
> > this point.
> > thanks,
> > lp
> > > Lance,
> > problem?
> > > > Ed,
> into
> > model.
> > seems to
> > reading
> successful.
> > getting
> > end
> > issue
> > > > with imports.
> > > > Any ideas?
> > > > thanks,
> > > > lp
Re: XSDResourceImpl.save help [message #32280 is a reply to message #32245] |
Tue, 28 October 2003 20:30 |
I assume the updateElement on the schema element is brutally slow?
I guess, my question would be, what actions should we take to update all our
uris after we change the name of a type entity? I assume you would have the
same problem with Attribute, Group and Element if you renamed them and they
were referenced by a like entity? Even if there was some form of update to
execute, it would only be successful for entities that are currently loaded
in the workspace? I don't think I like the direction this conversation is
going ;) Now you know why we use uuids instead of uris... we don't break
for anything except a delete (which is expected behavior) ;)
lp
news:3F9ED069.A7758857@ca.ibm.com...
> Lance,
serialization of
force way
the
processing
the
> > thanks,
> > lp
I
figure
work
> > for
hoping
optimistic
> > at
> > > this point.
> > > thanks,
> > > lp
> > > > Lance,
> > > problem?
> > > > > Ed,
> > into
Datatypes
> > > model.
reader
> > > seems to
> > > reading
> > successful.
are
> > > getting
and
> > > end
no
> > > issue
> > > > > with imports.
> > > > > Any ideas?
> > > > > thanks,
> > > > > lp
Re: XSDResourceImpl.save help [message #32315 is a reply to message #32280] |
Tue, 28 October 2003 20:44 |
Lance,
Definitely calling updateElement will have a significant cost. Your question
now is how to handle a general rename. You could use
XSDUtil.UsageCrossReferencer to find all uses and do a shallow updateElement,
i.e., updateElement(false), on each use. All the other named components will
have the same type of issue. Files that aren't loaded will clearly not be
updated. UUIDs have their benefits, but producing human readable results isn't
one of them. ;-)
> lp
> > Lance,
> serialization of
> force way
> the
> processing
> the
> > > thanks,
> > > lp
> I
> figure
> work
> > > for
> hoping
> optimistic
> > > at
> > > > this point.
> > > > thanks,
> > > > lp
> > > > > Lance,
> > > > problem?
> > > > > > Ed,
> > > into
> Datatypes
> > > > model.
> reader
> > > > seems to
> > > > reading
> > > successful.
> are
> > > > getting
> and
> > > > end
> no
> > > > issue
> > > > > > with imports.
> > > > > > Any ideas?
> > > > > > thanks,
> > > > > > lp
Re: XSDResourceImpl.save help [message #579982 is a reply to message #31999] |
Ed Merks Messages: 33142 Registered: July 2009 |
Lance,
> Ed,
> with imports.
> Any ideas?
> thanks,
> lp
Ed Merks
Re: XSDResourceImpl.save help [message #580003 is a reply to message #32034] |
this point.
thanks,
lp
> Lance,
problem?
> > Ed,
model.
seems to
reading
getting
end
issue
> > with imports.
> > Any ideas?
> > thanks,
> > lp
Re: XSDResourceImpl.save help [message #580024 is a reply to message #32068] |
thanks,
lp
for
> this point.
> thanks,
> lp
> > Lance,
> problem?
> > > Ed,
into
> model.
> seems to
> reading
successful.
> getting
> end
> issue
> > > with imports.
> > > Any ideas?
> > > thanks,
> > > lp
Re: XSDResourceImpl.save help [message #580066 is a reply to message #32068] |
Lance,
> this point.
> thanks,
> lp
> > Lance,
> problem?
> > > Ed,
> model.
> seems to
> reading
> getting
> end
> issue
> > > with imports.
> > > Any ideas?
> > > thanks,
> > > lp
Ed Merks
Re: XSDResourceImpl.save help [message #580093 is a reply to message #32104] |
Lance,
> thanks,
> lp
> for
> at
> > this point.
> > thanks,
> > lp
> > > Lance,
> > problem?
> > > > Ed,
> into
> > model.
> > seems to
> > reading
> successful.
> > getting
> > end
> > issue
> > > > with imports.
> > > > Any ideas?
> > > > thanks,
> > > > lp
Ed Merks
Re: XSDResourceImpl.save help [message #580113 is a reply to message #32068] |
thanks,
lp
for
> this point.
> thanks,
> lp
> > Lance,
> problem?
> > > Ed,
into
> model.
> seems to
> reading
successful.
> getting
> end
> issue
> > > with imports.
> > > Any ideas?
> > > thanks,
> > > lp
Re: XSDResourceImpl.save help [message #580145 is a reply to message #32210] |
Lance,
> thanks,
> lp
> for
> at
> > this point.
> > thanks,
> > lp
> > > Lance,
> > problem?
> > > > Ed,
> into
> > model.
> > seems to
> > reading
> successful.
> > getting
> > end
> > issue
> > > > with imports.
> > > > Any ideas?
> > > > thanks,
> > > > lp
Ed Merks
Re: XSDResourceImpl.save help [message #580166 is a reply to message #32245] |
lp
> Lance,
serialization of
force way
the
processing
the
> > thanks,
> > lp
I
figure
work
> > for
hoping
optimistic
> > at
> > > this point.
> > > thanks,
> > > lp
> > > > Lance,
> > > problem?
> > > > > Ed,
> > into
Datatypes
> > > model.
reader
> > > seems to
> > > reading
> > successful.
are
> > > getting
and
> > > end
no
> > > issue
> > > > > with imports.
> > > > > Any ideas?
> > > > > thanks,
> > > > > lp
Re: XSDResourceImpl.save help [message #580187 is a reply to message #32280] |
Lance,
one of them. ;-)
> lp
> > Lance,
> serialization of
> force way
> the
> processing
> the
> > > thanks,
> > > lp
> I
> figure
> work
> > > for
> hoping
> optimistic
> > > at
> > > > this point.
> > > > thanks,
> > > > lp
> > > > > Lance,
> > > > problem?
> > > > > > Ed,
> > > into
> Datatypes
> > > > model.
> reader
> > > > seems to
> > > > reading
> > > successful.
> are
> > > > getting
> and
> > > > end
> no
> > > > issue
> > > > > > with imports.
> > > > > > Any ideas?
> > > > > > thanks,
> > > > > > lp
Ed Merks
Current Time: Sat Apr 27 03:17:51 GMT 2024
Powered by FUDForum. Page generated in 0.05239 seconds
