Home » Modeling » TMF (Xtext) » How to run xtext Junit tests outside eclipse
How to run xtext Junit tests outside eclipse [message #1660953] Mon, 09 March 2015 08:10 Go to next message
I implemented several tests in the tests plugin in Xtext. I want to run these tests by a command line.
Can anyone help?
Re: How to run xtext Junit tests outside eclipse [message #1660973 is a reply to message #1660953] Mon, 09 March 2015 08:24 Go to previous messageGo to next message
Just invoke XXXStandaloneSetup.doSetup() and load your *.xxx resources
as normal EMF resources.
Ed Willink
> Can anyone help?
Re: How to run xtext Junit tests outside eclipse [message #1660990 is a reply to message #1660973] Mon, 09 March 2015 08:34 Go to previous messageGo to next message
I am totally new to Xtext so if you can help me with more steps of how to do this, that will be great Smile
Thanks alot Smile
Re: How to run xtext Junit tests outside eclipse [message #1661034 is a reply to message #1660990] Mon, 09 March 2015 08:56 Go to previous messageGo to next message
Simply run them as you would do it with normal junit tests
(e.g. using maven tycho surefire)
Re: How to run xtext Junit tests outside eclipse [message #1661035 is a reply to message #1661034] Mon, 09 March 2015 08:57 Go to previous messageGo to next message
https://github.com/cdietrich/xtext-maven-example
Re: How to run xtext Junit tests outside eclipse [message #1689755 is a reply to message #1661035] Tue, 24 March 2015 04:57 Go to previous messageGo to next message
I want to run the Junit tests in the MyLang.tests plugins using ANT unfortunately I cant use Maven. any help with that
Re: How to run xtext Junit tests outside eclipse [message #1689811 is a reply to message #1689755] Tue, 24 March 2015 07:34 Go to previous messageGo to next message
This should be 100 % straight forward as well
Re: How to run xtext Junit tests outside eclipse [message #1690165 is a reply to message #1689811] Wed, 25 March 2015 10:27 Go to previous messageGo to next message
I have been working on the ANT build.xml file and succeeded in compiling the junit tests but I am facing a strange error in the junit target. Here is my junit target and the used paths:
<property name="src.dir" value="src"/>
	<path id="junit.class.path">
		<pathelement path="${plugins_dir}/org.junit_4.11.0.v201303080030/junit.jar"/>
		<!-- <pathelement path="${plugins_dir}/org.hamcrest.core_1.3.0.v201303031735.jar"/>-->
		<pathelement path="${plugins_dir}/org.eclipse.emf.common_2.10.1.v20150123-0348.jar"/>
		<pathelement path="${plugins_dir}/org.eclipse.emf.ecore_2.10.2.v20150123-0348.jar"/>
		<pathelement path="${plugins_dir}/org.eclipse.xtext.junit4_2.8.1.v201503230617.jar"/>
		<pathelement location="bin"/>
	</path>
	<target name="runjunit" depends="compile,delete_logs">
		<junit  printsummary="yes" haltonfailure="no" showoutput="yes" fork="false" >
		  	<test name="my.lang.xtext.LANG.tests.GeneralTestCases" haltonfailure="no" outfile="result">
  		      <formatter type="plain"/>
  		      <formatter type="xml"/>
			</test>
				<classpath refid="junit.class.path">
					<!--<pathelement location="bin"/> -->
			</classpath>
		</junit>
	</target>
In the running of the ANT I got the error of class not found for the Hamcrest plugin so I added it and so other plugins were added as well because they were required. Then the ant gave the below error:
Type org.eclipse.xtext.junit4.XtextRunner not present
java.lang.TypeNotPresentException: Type org.eclipse.xtext.junit4.XtextRunner not present
at $Proxy4.value(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.junit4.XtextRunner
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at java.lang.Class.initAnnotationsIfNecessary(Unknown Source)
at java.lang.Class.getAnnotation(Unknown Source)
so I added the org.eclipse.xtext.junit4_2.8.1.v201503230617.jar. The strange thing is that in the run it gave the same error of class not found AGAIN for the HAMCREST although it is already in the pathelement!!! Any clue if there is a connection somehow between xtext.junit4 and the hamcrest? or how can I fix the dependency issue?!
[Updated on: Wed, 25 March 2015 10:27] by Moderator
Re: How to run xtext Junit tests outside eclipse [message #1690169 is a reply to message #1690165] Wed, 25 March 2015 10:41 Go to previous message
Hi i cannot help you with that. Using ant you have to manage clasdpath youseft. Maybe you can have a look at a xtext maven example to find out what tycho adds to the classpath
Previous Topic:Xtext refactoring support
Next Topic:cann't reference the instance in jar file or classpath model
Current Time: Thu Nov 06 09:40:55 EST 2025
Powered by FUDForum. Page generated in 0.07539 seconds
