Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem exporting as Deployable Feature
| Problem exporting as Deployable Feature [message #31911] |
Tue, 11 November 2008 05:18  |
Originally posted by: jmordax.terra.es
Hi, I have a Feature Project that includes 6 Plug-ins Projects.
The testings work fine. The Plug-ins Projects build perfectly.
But when I try to export the Feature as a Deployable Feature, there are
tons of errors building (compiling) the Plug-in Projects. It complains
about all imports (for example, SWT classes). It is like the Java Build
Path is lost or something like that when build is fired from the Feature
export process.
BTW, if I export all plug-ins as Plug-in or Fragment it works fine.
This worked fine with Eclipse R3.2 and now it is failing with Eclipse
R3.4.1. Is there any change I am required to do in this new version?
The same problem happens creating a Site Project.
Thanks in advance,
Chemi.
| Re: Problem exporting as Deployable Feature [message #31978 is a reply to message #31947] |
Tue, 11 November 2008 11:06   |
Chris Aniszczyk wrote:
> Can you post your feature.xml?
> Also, I assume you have nothing manually added to your build path, and
> all dependencies are coming from Require-Bundle/Import-Package and
> your Bundle-ClassPath is setup properly?
> Cheers,
> ~ Chris
Hi Chris.
But I have continued with my investigation during the day and I have
found "the problem" which doesn't make any sense to me.
The problem appears when you have more than one item listed in ws, os,
arch or nl properties.
For example with this content it fails:
<plugin
id="es.org.chemi.games.sokoban"
os="linux,win32"
ws="gtk,motif,win32"
nl="en"
arch="x86"
download-size="0"
install-size="0"
version="3.2.1"
unpack="false"/>
but with this one it works:
<plugin
os="linux"
ws="gtk"
nl="en"
arch="x86"
download-size="0"
install-size="0"
version="3.2.1"
unpack="false"/>
Does it make sense to you? what is the relationship between those
properties and Java compilation problems?
I have seen the same behavior with 3.3.2, 3.4.1 and 3.5M3
Thanks in advance,
Chemi.
I am going to try to create a dummy test case from scratch.
| Re: Problem exporting as Deployable Feature [message #32048 is a reply to message #31978] |
Tue, 11 November 2008 14:13   |
PDE/Build doesn't support lists in the os/ws/arch entries.
I'm surprised this worked in 3.2
-Andrew
>> Cheers,
>> ~ Chris
> Hi Chris.
> <plugin
> os="linux,win32"
> nl="en"
> arch="x86"
> download-size="0"
> install-size="0"
> version="3.2.1"
> unpack="false"/>
> <plugin
> os="linux"
> ws="gtk"
> nl="en"
> arch="x86"
> download-size="0"
> install-size="0"
> version="3.2.1"
> unpack="false"/>
> Thanks in advance,
> Chemi.
| Re: Problem exporting as Deployable Feature [message #32259 is a reply to message #32119] |
Wed, 12 November 2008 11:38  |
It is really just a feature that never got implemented.
The configs property in the build defines a list of os/ws/arch triplets.
This definitely can not take lists in a given triplet. This is
because the triplets end up being turned into properties set on an OSGi
state that we use to resolve everything and build the classpaths. A
platform specific bundle/fragment that does not match the triplets will
not resolve.
The os/ws/arch settings on the feature entries are used to decide
whether or not the bundle being included matches the set of configs
being built. If it does not match, then it does not get included. This
is more important when you include platforms that you are not building,
so we know we can safely ignore those bundles when they fail to resolve
in the state.
Your problem is likely that the list was never considered to match a
config being built and the bundle was not compiled. I think that
supporting lists would be a matter of improving the algorithm for
matching against the list of configs. Though there may be other things
that I haven't thought of.
-Andrew
>> -Andrew
> Hi Andrew. Thanks for your answer.
> But let me ask something else, is there any technical reason for this? I
> mean, I thought those four properties were just descriptive. For
> example, if I have tested my plug-in in Win32 and Motif, I document
> there this. Why a Plug-in can't document more than one Window System?
> And why this could affect to the compilation?
> Finally, why the Feature Editor let me select more than one value if it
> is not supported?
> Thanks again,
> Chemi.
| Re: Problem exporting as Deployable Feature [message #584705 is a reply to message #31911] |
Tue, 11 November 2008 10:21  |
> export process.
all dependencies are coming from Require-Bundle/Import-Package and your
~ Chris
| Re: Problem exporting as Deployable Feature [message #584725 is a reply to message #31947] |
> Cheers,
> ~ Chris
Hi Chris.
<plugin
os="linux,win32"
nl="en"
arch="x86"
download-size="0"
install-size="0"
version="3.2.1"
unpack="false"/>
<plugin
os="linux"
ws="gtk"
nl="en"
arch="x86"
download-size="0"
install-size="0"
version="3.2.1"
unpack="false"/>
Thanks in advance,
Chemi.
| Re: Problem exporting as Deployable Feature [message #584765 is a reply to message #31978] |
-Andrew
>> Cheers,
>> ~ Chris
> Hi Chris.
> <plugin
> os="linux,win32"
> nl="en"
> arch="x86"
> download-size="0"
> install-size="0"
> version="3.2.1"
> unpack="false"/>
> <plugin
> os="linux"
> ws="gtk"
> nl="en"
> arch="x86"
> download-size="0"
> install-size="0"
> version="3.2.1"
> unpack="false"/>
> Thanks in advance,
> Chemi.
| Re: Problem exporting as Deployable Feature [message #584794 is a reply to message #32048] |
Wed, 12 November 2008 02:32  |
> -Andrew
is not supported?
Thanks again,
Chemi.
| Re: Problem exporting as Deployable Feature [message #584845 is a reply to message #32119] |
not resolve.
in the state.
-Andrew
>> -Andrew
> is not supported?
> Thanks again,
> Chemi.
Current Time: Thu Nov 06 21:16:43 EST 2025
Powered by FUDForum. Page generated in 0.04887 seconds
